Old 10-11-2011, 11:46 PM   #1
floor over 24" o.c. truss joists
Hi guys, I hope somebody hear could help me with this. I've got a 40by 40 garage with the trusses made to have a 40by 12' room upstairs. I'm about to build my stairs, but I need to know how thick my floor has to be first. The trusses are 24" on center, bare joists right now. would one layer of threequarter ply be enough? Thank you, Joe
joebeadg is offline   Reply With Quote
Old 10-11-2011, 11:51 PM   #2
liscenced electrician
3/4 tongue and groove. Glued and screwed
jimmy21 is offline   Reply With Quote
Old 10-11-2011, 11:52 PM   #3
Tileguy
Bud Cline's Avatar
Might be helpful to know the depth of the trusses just for fun.
Old 10-12-2011, 12:06 AM   #4
They measure 7 and threesixteenths
Old 10-12-2011, 12:11 AM   #5
Missouri Bound's Avatar
So they are basically 2 X 8's....pretty bouncy over 12'...when you say room, do you mean storage?
Old 10-12-2011, 12:13 AM   #6
Tileguy
Bud Cline's Avatar
Are they trusses or joists?
And you say this structure was built to support a room up there?
Old 10-12-2011, 07:38 AM   #7
Super Moderator
Post some pictures---Your description does not sound right for a floor system ---What is the unsupported length of the joists---size of joists --???
Old 10-12-2011, 10:00 AM   #8
OK, I've scaned the truss diagram to my cp, but can't figure out how to post it here,
Old 10-12-2011, 10:41 AM   #9
Old 10-12-2011, 11:23 PM   #10
C:\Users\joe\Documents\My Scans\scan0037.bmp
Old 10-12-2011, 11:27 PM   #11
Old 10-12-2011, 11:44 PM   #12
Old 10-12-2011, 11:45 PM   #13
Finally!!!
Old 10-13-2011, 12:00 AM   #14
Tileguy
JazMan's Avatar
Hi Joe,
You'll have to contact the truss manufacturer for the info you need. We generally work with standard floor joists not what you've got there. So these trusses span almost 40 ft.? There are no supporting beams of walls under there? I can barely see some number, but it all depends how the space will be used.
Someone here might be able to research for you, but I suggest talking to the people that built the system.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 10-13-2011, 12:13 AM   #15
The unsupported span in the center and the additional load on the truss are the concerns here. Just looking at it, at best it is storage for light, low density items: Christmas decorations, lawn furniture....etc. But do what JazMan said and contact the mfg. for load specs. Not sure I would trust it for any real weight.
Sistering Joists and Adding a Beam Mikeman Building & Construction 6 09-30-2011 09:11 PM
Bubba's been here. Repairing sagging rim/floor joists. MattFels Building & Construction 7 02-09-2011 06:28 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 09:00 AM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Sister or Replace Floor Joists brando1118 Carpentry 25 10-26-2008 09:43 PM
