Floor Is Out 3/4" - Flooring - DIY Chatroom Home Improvement Forum
Old 09-25-2010, 10:59 AM   #1
Floor is out 3/4"
Hey guys. I am helping out a friend renovate his kitchen and we have a big problem with his floor... There is a hump in the middle of the floor throughout the entire room and is 3/4" high. We pulled the subfloor and it is the joists that are up. If we were to laminate the other joists with 2x10's to make the room true, the floor would be 3/4" higher then the new hardwood floors in the living room and hallway. he would like to have the floors be as level as possible with one another to have a smooth transition. Is there a way around this? Thanks
zetti1102 is offline   Reply With Quote
Old 09-25-2010, 11:16 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Can you see what is causing the joist to be up 3/4 inch? Is there a girder under that point?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-25-2010, 11:35 AM   #3
Everything looks to be fine from what i can see. Seems to be 3 joists that are up. I had an idea of planning down the joists so it makes them all even. they are 3x8's so i figure taking off a max of 3/4" wouldn't affect the structure.
Old 09-25-2010, 12:27 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
3X8s!!? are you sure they aren't 2X8s? Even if they are I sure would plane them down before I would raise the rest of the floor. I would even consider putting a drop girder under them and cutting a curf to let them down before raising the rest of the floor.
Jim
Old 09-25-2010, 12:56 PM   #5
1,000% POSITIVE they are 3x8's. House was built 1951, guess that's what they used around that time in N.Y.C.
Old 09-25-2010, 02:27 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 288
Wow, that is some heavy duty joist. All the better at least you have a very sturdy floor.
Jim
Old 09-26-2010, 12:02 AM   #7
jlhaslip's Avatar
Rewards Points: 1,502
planing them would be a good option, in my opinion.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 09-26-2010, 08:56 AM   #8
steveel's Avatar
Are there any wires, pipes, etc passing thru holes in those joists that right now are minimum allowed distance from top of joist, and if so will your inspector care if you plane off 3/4" of that distance? (And even if inspector won't care, if you have anything that close to top of joist beware of puncturing them when you nail flooring. May need to add those nailing-protection plates)
steveel is offline   Reply With Quote
Old 09-26-2010, 08:57 AM   #9
Yeah i guess planning them would be the best option... 3 - 3x8 joists at 20' long is gonna take awhile lol
Old 09-26-2010, 09:20 AM   #10
Steve, There are no pipes, wiring or anything through the joists. There is no inspector on this job.... He didn't want to get any permits or anything so that's all on him, I'm just helping him out. We are not changing any plumbing or electrical work, Just the structure will be changed because we will plane them down. On a 3x8 joist, could1/2 -3/4 of an inch really affect it that much?
Old 09-26-2010, 09:28 AM   #11
steveel's Avatar
beats me. The other posters don't think so. I just wanted to call attention to the pipes/wire issue in case you hadn't thought of it.
If its something you can do engineering wise, could you speed things up with a circ saw and some kind of homemade cutting guide? Watch for broken off flooring nails when you start up the planer.
have fun
Old 09-26-2010, 09:31 AM   #12
We pulled all the nails out clean. I think i would just use a power planer, have a good dewalt one. little safer then using a circ saw on the side of a joist i think.
3/4" hardwood over 3/4" T&G subfloor benjamincall Flooring 16 03-18-2010 10:46 PM
Cutting base around 3/4" corner bead Alan Carpentry 2 02-27-2010 02:32 PM
3/4" hardwood over "Sturd-i" OSB joemontana16 Flooring 1 02-20-2010 12:59 PM
3/4" T&G plywood over 1/2" subfloor Stude Building & Construction 14 12-26-2009 02:38 AM
3/4" Partical board underlayment OK for new 3/4" oak? housefixin Flooring 4 02-23-2008 04:36 PM
