Old 12-22-2009, 03:49 AM   #1
nakamu919
Floor noise
Just enclosed covered deck that was constructed on post and pier. Floor is 2x8s w/ 3/4" plywood on top. No insulation or anything under. Flooring not down yet, and neighbor is complaining that kids running on bare floor sounds like hammers pounding. Got half way through installing laminate floor with regular foam like underlayment, and neighbor again complained when kids were playing on the new floor. I saw a noise reducing underlayment at Home Depot, which may help a little, but I doubt will completely solve the problem. Don't need to completely eliminate noise because he is a neighbor, and not living on floor below or anything, but I want my kids to be able to play without bothering them. Would appreciate any suggestions on how to sound proof floor at this point.
nakamu919 is offline   Reply With Quote
Old 12-22-2009, 08:51 AM   #2
Next Time...New Build
Floor noise
Adding insulation underneath if it is accessible could help.
Batt insulation and some foam board could absorb some of the sound. I would also think that a sound dampening underlayment as you mentioned could help.
Once the floor is down and furniture is moved in it should also take out some of the echo that is probably bothering the neighbor.
Interesting to see other peoples take on this.
Good luck with the neighbor!!!
RickyBobby is offline   Reply With Quote
Old 12-22-2009, 10:43 AM   #3
Learning by Doing
Leah Frances's Avatar
Floor noise
My Grandmother used to tell us we sounded like a 'Herd of Elephants'. But, we were running around on the second floor.
Maybe if you gave us an idea of the geography of the situation it might help. Ie. it is hard from your OP to tell how your neighbor is subjected to the thundering footsteps of your children.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 12-22-2009, 10:46 AM   #4
Floor noise
Are you absolutely sold on the laminate? If not, return it and get some cheap carpet until the kids get a little older.
jerryh3 is offline   Reply With Quote
Old 12-22-2009, 10:51 AM   #5
Xtreme DIY'r
Floor noise
Kids make noise.....did you pull a permit ?
Neighbor as in house....Apt or condo ?
So the underside is open...probably amplifying the sound
That is probably your problem
Insulate it & close in under the floor
Old 12-22-2009, 10:55 AM   #6
Floor noise
does the bottom of the porch open to the neighbors below? you live above them?
Old 12-22-2009, 12:37 PM   #7
nakamu919
Floor noise
Thanks for the ideas. Carpet would work because other room exactly the same and no sound problems, but kids love laminate floor in grandma's house, so wanted to put it in. This is in Hawaii so I don't need to insulate under floor for hot/cold reasons. I did get a permit. Neighbor is in separate single family structure about 10 feet away. Below floor is easily accessible so I could close it in. Bottom of floor about 3' above ground on the side facing the neighbor. Thanks again for the help.
Old 12-22-2009, 08:14 PM   #8
firehawkmph's Avatar
Floor noise
I visited Hawaii once back in the early 90's. I thought you weren't supposed to spend much time indoors there. Get the neighbor some ear plugs and one of those little wave machines that make sounds like the ocean.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-22-2009, 11:03 PM   #9
Tileguy
Bud Cline's Avatar
Floor noise
I can understand wanting to get-along with the neighbors but "c'mon man." Maybe the neighbors need to get a life. Tell them to turn up the TV.
Old 12-22-2009, 11:11 PM   #10
Xtreme DIY'r
Floor noise
You could just close off the side facing the neighbors
Just bring the siding down to near the ground
Or something like a small solid fence
That way the noise will be blocked
Old 03-19-2011, 02:38 PM   #11
Floor noise
Just tell them that it is the floors way of communicating..
Really you can get special underlayments for laminate that can deaden the sound.. not found at home depot.. but a real store.. flooring retailers know what is good for condos and you can use that.
IceT is offline   Reply With Quote
