Floor Leveling Nightmare (potentially) - Flooring - DIY Chatroom Home Improvement Forum
Old 10-28-2014, 11:34 PM   #1
Rewards Points: 18
Floor leveling nightmare (potentially)
In 1983 some morons who owned what's now my house poured a cement pad for a bathroom. It's uneven: drops about 1" over the last 16" run on the north side! Don't get me started. Small bathroom: about 55 square feet, L-shaped. On top of the pad they appear to have glued some kind of crap flooring: it's a fine-grained particulate engineered wood material about 1" thick, like sawdust that's glued together. On top of that is some adhesive paper, and a thin sheet of hideous vinyl that's about 1/32 inch thick. Purple paisley.
I want to level the floor and put on ceramic tile. Is there any leveler product I can pour over this crap, that also would be ok for the tile? If not, any clue as to how to tear it all out? It's stuck on real good. There's also a bathtub, so don't know how i could cut it flush to the tub.
A nightmare.Any ideas? Wrecker ball is best, but I have a mortgage.
Thanks.
daviswhite is offline   Reply With Quote
Old 10-29-2014, 01:10 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,968
Feel your pain.
First step....remove all that crap down to the concrete.
Next step.....Leveling compound. HD carries it. Just follow the instructions. It's easy to use....just don't take short cuts or try to rush it.
The Following User Says Thank You to ddawg16 For This Useful Post:
daviswhite (10-29-2014)
Old 10-29-2014, 09:32 AM   #3
Rewards Points: 18
Any of you guys know what tool/saw to use to cut this subflooring out? I think it's called pressboard. It's very dense and glued on very well. As there's cement underneath I don't this this s**t flexes or moves.
Old 10-29-2014, 09:52 AM   #4
JOATMON
ddawg16's Avatar
It would help to post some picks.
One question.....is the wall framing on top of this stuff? If so, you have bigger problems.
Old 10-29-2014, 10:33 AM   #5
Rewards Points: 18
Photos
http://s872.photobucket.com/user/128bed/library/floor
Old 10-29-2014, 11:21 AM   #6
JOATMON
ddawg16's Avatar
Doesn't show much...but what it does show looks uuuuugly.
Does the wood extend under the walls?
Old 10-31-2014, 03:26 PM   #7
Rewards Points: 365
If it is already 1" out probably ceramatic tiles are not for you because it will crack in the future as your house starts to fall over.... You can use 2x6's or osb floor for a over it new subfloor. Maybe some vinyl flooring product.
begal is offline   Reply With Quote
Old 10-31-2014, 03:33 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can't believe this place sometimes.
What you have there is particle board. Particle board is bad news and cannot be used anywhere in a ceramic tile installation. Get rid of it at any cost. If it is under the tub and you won't do as you should and remove it then just break it off up to the tub.
This product is easy to deal with. Get a hammer and a pry bar and go for it. It isn't the big deal you are trying to make it out to be.
XXX
Old 10-31-2014, 03:34 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is this some kind of a joke?
This is Halloween note April Fools.
XXX
Old 10-31-2014, 03:54 PM   #10
Rewards Points: 365
If your subfloor is out in 50sq area by 1"???? Are you a joke, the subfloor is not stable and will crack the ceramic tile in few months or years...
Old 10-31-2014, 05:05 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So you are suggesting the guy create a 7" step to step up into his bathroom, lowering his ceiling to 7-1/2' and cutting seven or eight inches off of the bottom of the door, burying his tub or shower deep in the floor? What am I missing here?
XXX
Old 10-31-2014, 10:36 PM   #12
DIYer/PoleMonkey
clw1963's Avatar
Rewards Points: 262
Why's that? It's a concrete floor with a piece of particle board on it. Remove the wood, use a cement leveler.
clw1963 is offline   Reply With Quote
Old 10-31-2014, 10:43 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm tellin' ya !
Some of these people just insist on embarrassing themselves at the drop of a hat.
XXX
Deck Staining Nightmare steven994 Painting 6 04-06-2014 09:10 PM
cabinet staining nightmare kimma33 Painting 1 02-21-2011 07:46 AM
Flooring nightmare - need help valsey Flooring 12 10-02-2010 09:17 AM
1/2 bath remodel nightmare Jeekinz Plumbing 3 03-30-2007 11:25 AM
