Old 02-25-2009, 07:40 PM   #1
floor leveling compound
My entranceway landing is 6ft by 8 ft 5/8" tongue and groove. Joists are 8" 16 on centre. I plan on laying a hardwood 1 foot wide border around a pad of slate tile.
My real problem is the landings elevation are all over the place. I know I cannot make it "level" because the heighest point would make the first stair height way out of wake making a falling hazard.
I plan on using a leveling compound to make this landing all on the same plane. Then I plan on putting 1/2" plywood over top of the leveling compoound and screwing it down. Now I will use hardiboard for the tiles, lay them then put in whatever is necessary to get the hardwood to the right level......
My question is, Will this work? I heard that you can not drive nails through floor leveling compound as it will crumble eventually, but I have half inch plywood over top of the compound so I am hoping that that plywood would hold everything together..
geraldS is offline   Reply With Quote
Old 02-28-2009, 08:36 PM   #2
You should try glueing it down, and only put a few screws in it to let the glue set up.
sportsmansteve is offline   Reply With Quote
Old 03-01-2009, 08:30 AM   #3
Remodeling Contractor
You floor will still have too much flex to install slate. You need at least 1 1/4" plywood subfloor.
Old 03-01-2009, 09:16 AM   #4
Thanks for your response but I couldnt wait. I cut shims and nailed them to the floor ontop of the 5/8 inch plywood subfloor running only along the joists to make up for there irregularities. Then I poured floor leveling compound between these shims leveling everything out. Before the compound dried totaly I dropped 5/8 plywood over everything grain running the opposite direction of the original, and making sure the joints fell a three quaters of the way between studs so as not to sit on the studs themselves. Then I screwed the "underlay plywood" to the original subfloor only where the joists and shims were having screws only long enough to peirce the subloor and not the joists. I layed hardwood planks across this temporarily so nobody would walk between the joists causing the compound to deform and creating a void.....
This is all information I got from various forums.. Everybody has "the right way" to level out a floor and I simply combined them all.. which made for one long day.
Old 03-01-2009, 09:20 AM   #5
you now have 1 1/4" 2 X 5/8" so you will be fine. Use Ditra now to keep the floor movement isolated from the tile. Slate will crack easily if not properly applied.
More On This Topic
Vinyl tiles are one of the most commonly used floor coverings in homes today. The flooring comes in a variety of colors, textures and styles. Vinyl tiles are durable, decorative and easy to maintain. Follow the steps below to keep your vinyl floor in... Read More »
In this segment I'm going to talk to talk to you about how to bounce a ball. As you can see I'm on tile today and it's a little tricky cause it has cracks in it. So I really want to practice right in the middle but if you're on hardwood floor or linoleum... Read More »
Adding Water in Heroscape
Adding Water in Heroscape by Expert Village
Hi, I’m Mike Lopez with Expert Village and today we’ll be discussing the tabletop RPG Heroscape. Now water tiles are roughly half the size of your normal tiles, but they have the interlocking edges to put them together. You interlock them and... Read More »
If you're looking for carpeting you can install yourself consider carpet made in tiles of varying sizes. The major benefit of carpet tiles is the ability to replace only 1 or 2 tiles if staining occurs, while leaving the rest of the carpet intact. Follow... Read More »
Now in this clip we're going to look at different species of woods. Hardwoods and Softwoods, and talk about their different characteristics. Let's take a look. Now this particular example is Birch. It happens, this happens to be plywood. You can see that... Read More »
re: drywall compound over old lath gramps416 Drywall 5 01-17-2009 09:51 AM
Hairline crack in joint compound elbee Building & Construction 10 12-02-2008 06:57 PM
Toping Compound for texture....before or after drywall primer? yummy mummy Building & Construction 6 05-04-2008 11:57 PM
Which drywall compound should I use? yummy mummy Building & Construction 16 11-12-2007 05:00 PM
How to deal with setting drywall compound? KUIPORNG Remodeling 11 01-11-2007 09:22 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
