Floor Leveling Compond - Flooring - DIY Chatroom Home Improvement Forum
Old 08-05-2009, 12:06 AM   #1
toolbelt Tina's Avatar
floor leveling compond
Here is the situation. I leveled out or attempted to level out my cottage slab.
I used 2x4s as sleepers with 3/4 ply.
The individual are mostly level however I discovered I should have use a 7ft level instead of a 4. As the entire floor has a gradual slope
Can I correct this with floor leveling compound? I want to install hardwood.
I am guessing not... I'd figure maybe some felt paper and then pour... still no?
toolbelt Tina is offline   Reply With Quote
Old 08-07-2009, 01:01 PM   #2
Remodeling Contractor
leveling compound will work fine. But if there are no dips and bumps there is no need to address a flat out of level floor in order to install hardwood flooring.
How to spread drywall compond smoothly clemkonan Building & Construction 6 03-16-2009 10:35 AM
