Floor Leveler Compound On Polyurethane Finished Wood - Flooring - DIY Chatroom Home Improvement Forum
Old 03-11-2012, 10:03 AM   #1
Rewards Points: 12
Floor Leveler Compound on Polyurethane Finished Wood
I'm getting ready to install a floating laminate floor over an existing oak floor topped with polyurethane. Have a few dips/sags to level out. Folks at HD advised using the Henry 549 compound.
Other than well cleaning the areas to be leveled -- should I also lightly sand the finish to de-gloss a bit? Would think that helps the leveling compound stick better?
Thx
jzack is offline   Reply With Quote
Old 03-11-2012, 05:41 PM   #2
DIY staff
Rewards Points: 7,174
Read the label--most SLCs require a primer--I am not familiar with that brand--but I'll bet there is a companion primer--
Old 03-11-2012, 06:20 PM   #3
Rewards Points: 13,458
Why would you not refinsh the floors instead of going over it with laminite that will lower the value of the home and have a floor that looks like plastic?
Look in the houses for sale ads. There's lots that say real hard wood floors, none that say laminite floors.
Not trying to give you a hard time just looking out for your interest in the long run.
Old 03-11-2012, 07:40 PM   #4
Rewards Points: 12
Per the manufacturer web site - this type from Henry's is a direct apply application (ie., a number of surface types and no primer). However I know that sometimes there are helpful tricks that installers use for certain situations....
Old 03-11-2012, 07:45 PM   #5
Rewards Points: 12
Sadly this home was built in the early 80's and the flooring installed was done so, so with not great quality lumber. Not the best looking even with a re-finish (have seen some done by neighbors via contractors). Overlay we feel is the best economic way to go for this room - kind of wish that wasn't the case.....
Painting wood finished trim white... leverne99 Painting 12 06-06-2009 06:31 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Getting wood floors finished. MyFeetReek Flooring 1 10-10-2008 09:08 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Removing paint from finished wood 9c1 Painting 1 05-20-2007 06:14 PM
