Floor Leveler Compound on Polyurethane Finished Wood
I'm getting ready to install a floating laminate floor over an existing oak floor topped with polyurethane. Have a few dips/sags to level out. Folks at HD advised using the Henry 549 compound.
Other than well cleaning the areas to be leveled -- should I also lightly sand the finish to de-gloss a bit? Would think that helps the leveling compound stick better? Thx |
Read the label--most SLCs require a primer--I am not familiar with that brand--but I'll bet there is a companion primer--
Why would you not refinsh the floors instead of going over it with laminite that will lower the value of the home and have a floor that looks like plastic?
Look in the houses for sale ads. There's lots that say real hard wood floors, none that say laminite floors. Not trying to give you a hard time just looking out for your interest in the long run. |
| All times are GMT -4. The time now is 03:40 PM. |
