Floor Joist Water Damage - Flooring - DIY Chatroom Home Improvement Forum
Old 01-13-2012, 10:19 AM   #1
Floor joist water damage
I was trying to get a look around a leaking pipe down in my basement last night, and snapped a couple of pictures. This one troubles me - looks like the floor joist has taken quite a bit of water.
Still, I'm not an expert. Can anyone tell me how severely damaged this is?
Floor joist water damage-20120113_012552.jpg   Floor joist water damage-20120113_012534.jpg
thinksincode is offline   Reply With Quote
Old 01-13-2012, 10:47 AM   #2
Rewards Points: 13,764
What's above that, that could have caused that?
Looks more like were they had been a pipe and someone tryed to solder some while inplace. Looks like burn marks on the sides.
Old 01-13-2012, 10:51 AM   #3
This is right below the shower of the first floor bathroom, where I'm currently having a problem with water seeping through the floor.
Is this something that needs to be monitored, or something that needs to be addressed ASAP?
Old 01-13-2012, 10:58 AM   #4
Most often it's the drain that's leaking, run the water and check for a leak.
thinksincode (01-13-2012)
Old 01-13-2012, 12:37 PM   #5
Civil Engineer
Rewards Points: 4,792
That joist has sustained minimal damage. I would not touch it. However, you absolutely need to correct the source of the water damage, which may require replacement of piping, drains etc.
Water damage. How bad can it be? alexin General DIY Discussions 3 08-23-2010 01:53 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
