Floor Joist Direction Issue - Flooring - DIY Chatroom Home Improvement Forum
Old 06-28-2010, 12:45 PM   #1
floor joist direction issue
Hi,
I'm getting ready to install red oak flooring in my master bedroom. About half of the room is in the original part of the structure, the other half is part of an addition. The joists in the original part of the house run perpendicular to the direction of the original flooring. I want to run the new flooring in the same direction of all the rest as the home's original flooring.
I've read that running hardwood parallel to the floor joists is not advisable. Does anyone have any experience with this type of issue? What can I do to the addition part of the room to avoid any issues?
Thanks in advance!
moneypitowner is offline   Reply With Quote
Old 06-28-2010, 01:28 PM   #2
Handyman
Rewards Points: 512
What is on top of the joists? What type of subfloor?
canadaclub is offline   Reply With Quote
Old 06-28-2010, 01:53 PM   #3
Hey, thanks for the response. The subfloor consists of 2 layers of 1/2" plywood.
Old 06-28-2010, 02:07 PM   #4
Handyman
Rewards Points: 512
Ideally its best if you can run perpendular to the joists but I would say you will be fine. Just be sure to screw (not nail) the subloor to the joists...say, every 8" on the deck and every 4-6" at the seams. You can also apply some PL Premium if it puts your mind at ease but I generally only use that on the perimeter boards
Interlock Paver Issue cbadrik Landscaping & Lawn Care 2 07-27-2009 07:29 PM
Carpet on Stairs, Hallway: Nap Direction Carol Emmarie Flooring 5 03-26-2009 11:40 AM
HELP - with my breaker box. Interesting issue. LordX Electrical 75 02-23-2009 03:14 PM
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 01:34 PM
Fireplace framing/tile issue robdville Building & Construction 13 11-14-2008 07:14 AM
