Floor Insulation On Pier & Beam Home - Flooring - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 05:56 PM   #1
Floor Insulation on pier & beam home
Live in Texas and building a pier and beam home; looking for ideas on floor insulation without trapping moisture and creating a vapor barrier. There will be a faux rock skirting that goes around the home...
When I was picking up the trusses months ago, a worker there suggested typical batts in between floor trusses with chicken wire tacked onto it.
Waymo is offline   Reply With Quote
building a pier or dock for waterfront home chuckdavin Building & Construction 1 12-02-2010 08:07 PM
Installing wonderboard on pier and beam foundation Harrington Flooring 3 12-01-2010 01:29 PM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 07:20 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
Need advice on footer pier problem paredown Building & Construction 3 03-20-2009 10:08 PM
