#16 |
Tileguy
"floor flex" again
If there's too much month left at the end of your money, you know what to do. It's all about priorities. There isn't that much difference in cost between the options if you're doing the installation yourself. If you're not able, different story.
Frankly I think if the small deflection deficit was only from the joists, (as yours), I would be inclined to go for it anyway knowing the charts are very conservative and with a little overkill built in. My answer would be different if the deflection between the joists was too high. Different dynamics in the latter. Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
#17 |
"floor flex" again
ok,on to something else: (not sure if I should start another topic
but...I've got this "powder room" I'm redoing. (yes Jaz,tile will be going down!) anyway,I'm removing the vinyl flooring and find that underneath is a 1/4 in. underlayment of what looks like "luan". should I leave it and put "Ditra" over it or remove it and put the Ditra right on the 3/4 plywood? or maybe remove it and replace it with 1/4 plywood? tnx, |
#18 |
Tileguy
"floor flex" again
You must remove the luan, then re-screw the subfloor and install either 1/4" concrete board or Ditra. No 1/4" ply allowed in a tile installation. How's the joists deflection in that part of the house?
Jaz
#19 | |
"floor flex" againQuote:
the luan is stapled down so it shouldn't be too hard to remove. I ran the numbers and deflection is ok. tnx, |
#20 |
Tileguy
"floor flex" again
OK then. If the numbers are good, looks good, and feels good, then I guess you're good!
But yes you always re-fasten the subfloor even if there's no squeaks. Today no squeaks, in a few months it all changes. Jaz
#21 |
"floor flex" again
ok "Jaz", I removed the top layer of vinyl and the next layer of "luan" and found linoleum under THAT and removed it.under that linoleum is what looks like 1/4 ply. (as an underlayment for the linoleun) I am dead positive that there is no more linoleum, just a subfloor of 3/4 ply and 1/4 ply on top of that. since the previous owner must have put that 1/4 ply down even before he built the walls (the house was new and I believe he finished that end of the house) , (and installed the vanity)it's going to be a royal P.I.T.A. to remove THAT.
can I leave it and tile over it? yeah,I know you said 1/4 ply is a no-no but I just can't see that 1/4 ply on top of 3/4 ply is anything but a sub-floor of 1 in. ply. is this wrong?tnx, |
#22 | |
Tileguy
"floor flex" again
There is zero chance that the 1/4" ply for the older vinyl is under the walls. It might be under the vanity, easy enough to figure that out. Instead of doing this the hard way, why don't you drill a hole or use a hole-saw thingy for making holes in doors to see what's there?
Next tile you remove vinyl tiles or sheet vinyl with 1/4" ply under it, remove both in the same operation. It' easier, faster and you won't been scraping any asbestos backing which is found in older sheet goods. Jaz
#23 |
"floor flex" again
uh Jaz, as much as I respect your knowledge of tiling, I've got to say that you are dead wrong on this one! in my previous post I said that the former owner finished the end of the house containing the "powder room". he evidently laid down 1/4 ply all over,knowing that he was going to lay down linoleum everywhere, THEN, he put up the walls. so you can see my predicament, if I somehow manage to remove that 1/4 ply (with lots of cutting), that floor will be 1/4 in. lower than the rest of the floor in the laundry/utility room. THEN when I get around to tiling THAT area, I'll have the same problem,only THIS time I'll have much more cutting to do in order to remove the 1/4 ply. so,the question is,how wouls you handle such a job? would you still insist that the 1/4 has to go no matter what? tnx, |
#24 | ||
Tileguy
![]() Quote:
But even so, it's not that hard to remove it, just get a toe-kick saw. What are your plans for the tile installation method if you left the 1/4" ply? name the methods and materials. Is it luaun or pine ply? Jaz
#25 |
"floor flex" again
Jaz,
it looks like regular pine 1/4 ply. if I left it,I'd screw everything down nice and tight, then I'd lay on "ditra" using a modified thin set, then my tile would go on using un-modified thinset. btw: what's a "toe-kick saw"? tnx, |
#26 | |
Tileguy
Jaz
#27 |
"floor flex" again
I can see that in the wrong hands (like mine
),there dould be another "Texas chain saw massacre"...in colorado)
| Display Modes | |
