Floor For Dog Room/cage - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ZZZZZ
Old 01-10-2017, 05:18 PM   #1
Rewards Points: 32
Floor for dog room/cage
When we are both out of the house, we put the dog downstairs (unfinished basement) in a large 10x10 dog cage. She loves it down there, but sometimes she has accidents. I dont want dog urine soaking into the concrete, so i am looking for a decent solution. I want something soakproof.
*it has to be something that she won't be able to destroy. If she can get it into her mouth, it will be dstroyed. (Foam utility mats etc).
Two ideas I have, but I dont think they are great..
1. Get "sheet vinyl". They sell this in 12 foot wide rolls, so i could get one piece. No seams = no urine touching the concrete.
2. Lay plywood down over the entire area, and get some sort of vinyl/laminate tiles to stick to it.
Erikz is offline   Reply With Quote
Old 01-10-2017, 06:09 PM   #2
ZZZZZ's Avatar
Rewards Points: 2,164
Re: Floor for dog room/cage
A former neighbor of mine trained his Chihuahua to pee in a large pan of kitty litter.
lenaitch likes this.
Just my 7 cents (2 cents after taxes and inflation).
ZZZZZ is online now   Reply With Quote
Old 01-10-2017, 07:30 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 1,664
If you put anything down that acts like a barrier, such as sheet poly, laminate, etc. any urine will either run off to your concrete or lie in a puddle (not poodle), depending on the grade of your floor. You can get 'training pads' at most pet stores but 10'x10' is a big area. Does she 'go' just anywhere or in a specific spot in the cage? If it's very infrequent, buy some cheap carpet and throw out when necessary.
lenaitch is offline   Reply With Quote
Old 01-10-2017, 08:44 PM   #4
firehawkmph's Avatar
Rewards Points: 1,884
What kind of dog is it and how long are you leaving her in there for?
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-11-2017, 03:04 PM   #5
Rewards Points: 652
I've seen some dogs destroy sheet vinyl glued to concrete.
Concrete is not a nice surface for any animal to be on, including humans. Generally speaking, a crate being used as a bathroom by a dog is an indication the crate may be too large. Since you say 10' x 10', I can see that being the case here.
stick\shift is offline   Reply With Quote
Old 01-11-2017, 04:14 PM   #6
Rewards Points: 2
You could paint the concrete with garage-floor paint.
Pegowow is offline   Reply With Quote
