Floor Cover Opinion - Concrete Slab Floors With Cinderblock Walls - Flooring - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 05:24 PM   #1
floor cover opinion - concrete slab floors with cinderblock walls
4 room cinderblock house with interior cinderblock walls and concrete floors in NC. concrete slab floors are built directly on ground.
i pulled up the carpet and would like laminate plank floors due to allergies BUT concerned about moisture being an issue.
this will also be a rental eventually so may be unoccupied some months with no controlled temperature during that time.
what are your thoughts on laminate in this situation?
thanks bunches!!!
suevwbug is offline   Reply With Quote
Old 04-24-2011, 05:45 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
First thing to do is a moisture test.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-24-2011, 07:32 PM   #3
hey rusty!
thanks for mighty quick response.
how do i perform a moisture test myself?
thanks!
Old 04-24-2011, 08:11 PM   #4
Rewards Points: 52
Not the most accurate, but you can tape down a 3' square piece of plastic sheeting, like you would put over a window to keep out the cold, let it stay for a few days and see how much moisture gathers under it.
Old 04-25-2011, 08:52 AM   #5
will try that this week and let you know what results are.
if i see any drops does that indicate moisture, or is a drop or two here & there normal? guess i better just do the test and see what i see...
i'll report back before end of week to let you know how it goes.
thanks!
Old 04-29-2011, 08:56 AM   #6
no moisture from the plastic i taped down in all 4 rooms.
what do you recommend me putting down between the concrete and the laminate?
i know i have to acclimate the laminate in the house at least 48 hours before installing it, but will it matter that 6 months or a year from now if the house is empty for months at a time with no temperature control - i am just afraid under those circumstances it may buckle.
thanks again for your time!
Old 05-09-2011, 10:22 PM   #7
?laminate or allure vinyl plank flooring?
moisture test turned out fine - did my own plastic taped down test & had moisture test done by home depot.
now the big question - laminate or allure vinyl plank flooring???
i've read horror stories in this forum about the allure plank on concrete, but then again isn't there a possibility of laminate buckling. the money isn't an issue i just don't want what i do put down to cause me headaches or more money down the road...
thanks for any recommendations!!!
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 01:44 PM
Finishing basement - concrete walls options droyer Building & Construction 1 01-13-2010 07:27 PM
How to cut a hole in a concrete floor slab tomseeley General DIY Discussions 7 06-10-2009 03:32 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 01:17 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 11:29 AM
