Floor Cleaning And Re-coat - Flooring - DIY Chatroom Home Improvement Forum
Old 01-17-2008, 12:24 PM   #1
Floor cleaning and re-coat
I have wood floors in my house, but I do not believe they are hardwood. We had the floors sanded and urethaned 4.5 years ago before we moved in.
In the high traffic ares, I can definitely see some dirt build up, and I suspect that the floors need a new coat.
I was told that the floors were on their last sanding, so I really want to clean and recoat the floors before I have some tennants move in on Feb 1.
I am not afraid of giving them a good scrub, but I want to know what the best cleaner is, as time is most valuable .
Also, anybody know where I can get urethane in a 5 gallon bucket here in Metro detroit without paying retail Home Depot prices?
beertestr is offline   Reply With Quote
Old 01-19-2008, 06:21 PM   #2
Your best bet is what they call a screen and coat or re-coat. This means that the flooring gets a light sanding over the entire floor to remove the top layer(s) of finish, but not all the way down to bare wood. Then you need to apply 2 coats of finish.
Try using Bona Kemi Traffic or Basic Coatings Street Shoe. You can find either products at your local flooring distributors.
mpeterson72 is offline   Reply With Quote
Can you put brown coat on if it's going to rain? Not Sure Building & Construction 3 03-23-2009 07:57 AM
stucco finish coat efaxsteph Building & Construction 2 03-24-2008 07:23 PM
Skim coat for damaged plaster walls slapdash Remodeling 4 10-14-2007 06:27 AM
Round 2 & 2nd coat question usaalways Painting 5 06-24-2007 09:20 AM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
