Old 10-21-2009, 04:02 PM   #1
Default Floor burns in basement ceiling, likely under stove
While in my basement this AM, I looked up among the floor joist and noticed on the plywood underlying the first floor what appeared to be two "burn" mark - irregular ciricles about 3 inches wide. The two marks are below the stove in my kitchen, as best as I can see. I beleive that the marks correspond to the "feet" of the stove. I suppose the reason for this is as obvious as it is alarming. Though I suspect it will prove to be burned as well, the flooring immediately under the stove's not yet been examined (the stove is a massive six-burner unit with a vent hood and warming rack arrangement afixed to it, so there'd be a good amount of dismantling before I can get it out). What I am wondering is if this has occured to anyone else? Presuming the floor beneath the stove is still viable, would lining the area under the stove with cermaic tile offer sufficient protection? (Currently there's hardwood throughout the kitchen).
brokenknees is offline   Reply With Quote
Old 10-21-2009, 04:59 PM   #2
ArmchairDIY's Avatar
One never knows for certain from only a written description, but I highly doubt you are seeing burn marks caused by the stove.
Is there copper plumbing pipes near the burn marks. I'm thinking they may have been burned by a plumber soldering fittings possibly.
ArmchairDIY is offline   Reply With Quote
Old 10-21-2009, 05:11 PM   #3
"Is there copper plumbing pipes near the burn marks. I'm thinking they may have been burned by a plumber soldering fittings possibly."
Good point. I'll check that. My recollection is that there is not a pipe running along the area question (and definitely not immediately beneath the burns) but I will look. Consistent with your suggestion, the burns would otherwise seem to be coming from the bottom up (i.e., the obviously burned "skin" of the plywood is on the ceiling side in the basement.
Old 10-21-2009, 05:17 PM   #4
Jack of all - master none
hyunelan2's Avatar
Are you sure they are burns, and not something like spray-paint from when the wood was stacked somewhere? To actually scorch the wood on the outside, from above, I think the board would have combusted before those char marks would appear on the other side of the wood.
hyunelan2 is offline   Reply With Quote
Old 10-21-2009, 05:18 PM   #5
My thought is if the floor was burned from the top side to the extent it was visible in the basement the stove would be falling through the floor and you would have smelled smoke in the upstairs. I believe there is another explanation for the spots.
Old 10-21-2009, 07:33 PM   #6
37 year installer
rusty baker's Avatar
If it had burnt thru, the flooring above would be scorched in a bigger area.
If'n you can't fix it with duct tape, it can't be fixed!
Old 10-21-2009, 08:04 PM   #7
Learning by Doing
Leah Frances's Avatar
Any kids/teenagers in the house?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Tags
burns, fire, flooring, range, stove
More On This Topic
Home Remedy for Burns
Home Remedy for Burns by Expert Village
Hi I’m Angela on behalf of Expert Village.com and right now I am going to show you a home remedy for a burn. Let’s say you burned your finger on a stove or grease that flew up while you were frying something. What you want to do immediately... Read More »
This is Ben Ingham with Expert Village talking about a walk out basement. The exterior of this cinder block wall I have painted with 2 coats of foundation paint which is basically a very thin tar that it suppose to penetrate the side of it. I also have... Read More »
Hi I am Drew Fendy, master home inspector. I have been inspecting for over 24 years. Today we are going to describe how to install an electrical receptacle for Expertvillage.com. Okay, now we need to drill a hole from the basement up through into the... Read More »
Hi! This is Steven Keilholz Flooring on behalf of Expertvillage.com. Today I am going to show you how to prep up the floor for a new installation for flooring in your basement. The first thing we are going to be using is a floor scraper. Second thing we... Read More »
You found the house of your dreams, and all the inspections, mortgage paperwork and contracts are done. It's time for that final walk-through before heading off to the closing. Don't take a final walk-through lightly; it's your last chance to spot... Read More »
basement - steel framing / existing drop ceiling j-dude Remodeling 0 07-08-2009 11:59 AM
Drywall ceiling in basement using floor trusses ralphfravel Building & Construction 10 04-03-2009 09:12 AM
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 08:58 PM
Drywall vs. drop ceiling for basement DIY4EVER Building & Construction 23 11-15-2008 09:24 AM
Acoustical Insulation for basement ceiling newcondo Building & Construction 8 08-26-2008 12:50 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
