Floodable Flooring Options - Flooring - DIY Chatroom Home Improvement Forum
Old 10-18-2012, 10:27 AM   #1
floodable flooring options
hi all. 3 months after buying a little camp/house on the bayou, Isaac brought 3 foot flooding. among the issues to address are new flooring, to replace the vinyl tile, some of which is still adhering quite well, but others have popped.
subfloor is plywood, seems to be pretty sound (no noted creaking, although there are some patches). these are a few feet above grade, over a pretty low crawl space
have done tons of research on this, and there are some conflicting principles: waterproof flooring is good to prevent infiltration, but bad for drying things out, and since the underside of the plywood is exposed to flood waters, it does get wet and sat in water a couple of days with Isaac (though it has pretty much dried out fine, in spite of the low permeability of the vinyl tiling.)
options under consideration:
just redo vinyl. cheap, fairly easy, not a big deal if/when the next storm hits (these hundred year storms coming twice in the last decade kinda gives pause). not the nicest look, but the place is a bit rustic anyway
another resilient flooring, maybe rubber. nicer look, might be salvageable in a future storm. impervious to the funky bayou flood waters
some form of ceramic/clay tile in thinset or mortar. would hate to have to replace this if the subfloor has to be taken out, but in best case scenario could be hosed off and disinfected. questions about best materials, from mortar(mastic vs mud), tile composition (glazed/porcelain vs permeable clays) and grouts(waterproof vs permeable). definitely the nicest look and materials not much higher than resilient options
no case really to be made for laminates unless someone tells me otherwise. I'm open minded. Thanks in advance
mnr3 is offline   Reply With Quote
DuraFlex Epoxy Flooring Problem Amon Flooring 9 11-04-2013 12:47 PM
asbestos in our ripped up flooring?? 6fthook Flooring 16 07-29-2011 11:06 PM
Hardwood flooring mess options WillK Flooring 3 07-15-2011 09:32 AM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 12:23 PM
Basement flooring options CooperChloe General DIY Discussions 3 01-25-2009 04:30 AM
