Floating Vinyl Floor - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 12:13 PM   #16
Steeler99's Avatar
wow, you did a lot of work on your own...why not consider doing the flooring yourself. Alot of the tongue and groove flooring is really simple to put in, easier than you think.
I watched a good friend of mind and his wife do it...neither of them knew much about carpentry at all, they flew right through it.
Even tiling is easier than you think, as long as you're not doing extravagant tiling.
You can rent a tile saw for about 25-40 bucks a day...and I did almost all the main tiling first and then rented the saw for a day to finish the rest of the cuts.
Personally, I don't like laminates....for me, they always seem to fail and by the time you replace them every five to ten years, its worth the extra investment to do it with better materials the first time. You can check ebay and other places for better materials, builders auctions, etc.
Steeler99 is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Remove old vinyl floor that's curling at the edges? julzology Flooring 9 03-20-2011 06:07 PM
How can I know if my kitchen sheet vinyl floor has an asbestos problem? hackwriter Flooring 4 01-23-2011 02:35 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
Floating Floor in the kitchen sweetwillie66 Flooring 3 02-12-2006 02:10 PM
