Floating Floor Questions - Flooring - DIY Chatroom Home Improvement Forum
Old 05-19-2008, 11:04 AM   #1
Rewards Points: 157
Floating floor questions
Dear friends,
Maybe somebody could answer few questions concerning floating floor. I just purchased Schön Engineered maple floor through Lumber Liquidators. Unfortunately, it did not include any instructions, and the information I found in the Internet is controversial.
For example, I don't know whether sheets of plastic film (vapor barrier over concrete slab) should overlap or not, should they be taped to each other or not. Also I don't understand if the pieces of floor should be glued to each other - as I have said, the information online is controversial, and I cannot find Schön's website to read about that very product.
Maybe somebody could answer these questions and also provide me with a link to the instructions with pictures.
Thank you in advance.
dpreznik is offline   Reply With Quote
Old 05-19-2008, 06:35 PM   #2
Rewards Points: 212
Originally Posted by dpreznik View Post
Dear friends,
I saw your post and did a little searching on internet. Have not used this product, but did find a link to installation.
You could call Lumber Liquidators for some details.
Does product say it is quick click??
Here is link I found:
http://www.lumberliquidators.com/cus...e=inst_qc_step
orange is offline   Reply With Quote
Old 05-20-2008, 10:11 AM   #3
Rewards Points: 157
Thank you very much for this help. This site is exactly what I need.
Yes, it is quick click. Unfortunately, this instruction also contain contradiction.
It says:
"Place tongue side against the wall, groove side out."
This contradicts to the pictures placed there, and it contradicts the information given by other web sites I found.
Also it doesn't say whether the sheets of plastic vapor barrier should overlap or just be taped.
Old 05-20-2008, 11:00 AM   #4
Rewards Points: 212
It says:
I did some more digging.
I found this site at Lumber Liquidators for asking questions
http://www.lumberliquidators.com/cus...me=Flooring101
I entered "shon quick clic" (without quotes).
It gave back a list, but the important one is:
Schön Quick Click floating instructions 9/16"x 7 1/2" with address
http://server.iad.liveperson.net/hc/s-13045352/cmd/kbresource/kb-936374745394651101/view_document!PAGETYPE?sq=shon%2bquick%2bclic&sf=1 01113&sg=0&st=862286&documentid=225436&action=view
Click that link and get a reference document - 7 pages of how to install -
click the little icon at extreme right (under Format) to download the document.
It says continuous vapor barrier....
Anyway give it a try.
Old 05-21-2008, 03:36 PM   #5
Rewards Points: 157
Thank you very much for your help! I started my project... It seems to be working so far.
Old 05-27-2008, 11:53 AM   #6
Rewards Points: 157
I am done with laying the floor now. The only question left that I have is how to attach wooden baseboards to the brick wall. Is there any glue or something?
Thanks in advance for any help.
Old 05-27-2008, 12:32 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Typically brick walls don't get any baseboards. The cuts are perfected at installation and the gap is caulked.
Old 05-27-2008, 01:16 PM   #8
Rewards Points: 157
But now I have that blue plastic film (vapor barrier) sticking from under the floor, so I wanted to hide it somehow. And what caulking do you mean?
Old 05-27-2008, 03:52 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
...now I have that blue plastic film (vapor barrier) sticking from under the floor...
So cut it off.
There are any number of flexible caulks that can be used.
Am I missing something here?
Old 05-28-2008, 08:32 AM   #10
Rewards Points: 157
So cut it off.
The brick wall is sometimes getting hot (the fireplace is right behind it), so I don't know how calk will behave. Also I thought the vapor barrier should be wider than the floor to prevent moisture penetrating...
Floating stairs - HELP! ryandiy Building & Construction 15 12-08-2011 01:50 PM
can engineered hardwood be a floating floor? smythe01 Flooring 10 07-09-2008 11:16 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
Basement Framing - Floating Slab JackOfAllTrades Building & Construction 8 02-05-2008 04:20 PM
Floating Walls KenG Carpentry 8 12-02-2007 01:29 PM
