Old 01-28-2006, 01:50 AM   #1
Send a message via Yahoo to gwendda
Question
Floating floor over cement
I am installing a floating floor over cement slab. The flooring has the underlayment attached to the back. Is there a product I could lay under the entire floor to form a vapor barrier or will the attached underlayment suffice? ~ Gwen
gwendda is offline   Reply With Quote
Old 01-28-2006, 09:25 AM   #2
Contractor
In Oregon I would apply 2 coats of concrete sealer and a membrane (VisQueen) with seams taped for the full length.
Teetorbilt is offline   Reply With Quote
Old 01-28-2006, 01:55 PM   #3
I will seal the concrete and a thin membrane will work for a barrier ~ PS I am in the desert ~ the sealer will help keep any previous animal odors from surfacing.
Old 01-28-2006, 02:14 PM   #4
Floorwizard's Avatar
6 mil poly.
but you need to test to see how much vapor is actually occuring.
tape a square of 6 mil on all 4 sides and wait a day to look for condensation.
or get a moisture test from HD
Floorwizard is offline   Reply With Quote
Old 07-18-2006, 05:58 PM   #5
try roughing up the floor if you are doing a membrane sealer. Also stay away from the acrylics from what I've heard they fail in a couple of years and you could have problems... the stuff I hear you should use is an epoxy... though it costs more. If moisture was your only concern, you could probably use a penetrating sealer.
Pilot is offline   Reply With Quote
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
Fence problems-Cement or No Cement WBMill Landscaping & Lawn Care 8 06-17-2007 03:36 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
HELP! Cement in PVC drain pipe KAT Plumbing 7 05-18-2006 08:17 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
