Floating Floor / Cutting To Measure - Flooring - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By samjg1
Old 05-14-2016, 01:39 PM   #1
NorPlan's Avatar
Rewards Points: 216
Floating Floor / Cutting to Measure
Were Replacing the Floating Floor in a Bedroom.. Curious if using the Mitter Saw , replaced the Blade last fall with your standard multipurpose cutting blade would be Ok ?? Or could we expect chipping and what not ??
NorPlan is offline   Reply With Quote
Old 05-14-2016, 02:05 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Re: Floating Floor / Cutting to Measure
What is the floating floor product? Hardwood, laminate, vinyl?
The cut ends / edges will be covered with a trim piece so some chipping is not a problem.
Coastal South Carolina
Old 05-14-2016, 02:15 PM   #3
NorPlan's Avatar
Rewards Points: 216
Laminate / Megaloc by Classen , Made in Germany
Old 05-14-2016, 03:09 PM   #4
A "Handy Husband"
rjniles's Avatar
I would spring for a new plywood blade.
Old 05-14-2016, 08:44 PM   #5
jlhaslip's Avatar
Rewards Points: 952
I have used this blade with great success.
Around $100 USD.
http://www.amazon.com/dp/B00EV5A3KW/?tag=cu0e-20
Worth resharpening after you are done with your flooring job. Makes an excellent finish blade.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 05-14-2016, 10:08 PM   #6
A "Handy Husband"
rjniles's Avatar
Around $100 USD.
Not sure I would spend that much to cut laminate. In fact I am sure i wouldn't. The cut edges don't show. And if they do, you are installing it wrong. Buy a cheap plywood blade and pitch it. $10 for a 10" blade at big orange.
Old 05-15-2016, 12:09 AM   #7
samjg1's Avatar
Rewards Points: 214
I'd just use a multi purpose carbide blade. I've been using the same one for about 1200 sq ft of laminate floor and it's still going strong, with no chipping.
The finish on a laminate floor is very hard on blades.
samjg1 is offline   Reply With Quote
Old 05-15-2016, 07:17 AM   #8
NorPlan's Avatar
Rewards Points: 216
Thanks ... The Room is 25' L X 12' W.... With about 2 1/2' indent for a Doorway at one end..... Was told if we're doing the job right, any cut edges will be under the wall trim..
Old 05-15-2016, 08:58 AM   #9
Rewards Points: 13,270
If you do get chipping try flipping the piece over so the chipping will be on the back side.
Old 05-15-2016, 09:13 AM   #10
samjg1's Avatar
Rewards Points: 214
That's correct. Either the base moulding or the quarter round will cover the required gap between the floor and wall.
Just for information, if for some reason you want to be sure of no chipping, on a miter saw the blade cuts downward which makes a smooth cut, so cut with the piece face up.
If you use a circular saw you'd cut with the piece face down because the blade cuts in an upward direction.
rjniles likes this.
Floating Basement Walls jonhayden Building & Construction 15 12-16-2013 09:53 PM
Floating wall for basement pattyobrien3 Remodeling 11 11-07-2012 05:58 AM
Potential buyer of my house withdrew interest-no bsmt floating walls gjw Carpentry 1 11-08-2010 12:37 PM
Installing an island on floating engineered wood floor funktional Flooring 11 03-14-2008 07:19 AM
