Floating Floor In A Crawlspace - Flooring - DIY Chatroom Home Improvement Forum
Old 01-02-2011, 08:46 PM   #1
Question
Floating floor in a crawlspace
Hey all... wanted to pose a question before I move forward with my plans. I have a 6ft tall crawlspace with what looks to be a hard dirt floor with plastic layed over it. I own a tri-level home and the crawlspace is accessible through the bottom floor, which is ground level. The crawlspace, however, is not ground level and goes down 4 - 5 steps. I live in CO and it's very dry here. I wanted to put in a floating floor perhaps so I didn't have to put shoes on every time I go down into the space, as well as to keep all my storage stuff of the dirt floor. The crawlspace walls are all concreate as well.
How should I proceed with the floor? I was thinking either
A: using treated lumbar as floor joists, putting them directly on the dirt floor, and then putting plywood over it
or
B: hanging the joists by brackets attached to the concreate walls leaving an inch or 2 of empty space underneath the joists and the dirt floor.
CO DIYer is offline   Reply With Quote
getting the most out of a heated crawlspace Gerry Fossum HVAC 2 06-08-2011 07:42 PM
conditioned crawlspace fan albertpinto HVAC 4 12-27-2010 04:46 AM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 01:35 PM
Insulating an unheated crawlspace indignatz Building & Construction 7 10-28-2009 06:29 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
