Floating Floor Boards Over Uneven Tiles - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 03:31 PM   #1
floating floor boards over uneven tiles
I am intalling timber laminate floor boards and the room i am doing it in had half ceramic tiles and half carpet. I have removed the carpet and the tiles are still there and are quite hard to remove. I wanted to know is it possible to lay a double underlay on the concrete where the carpet was to make it he same level as the tiles, and then lay the floating floor boards over the whole floor?
joey44 is offline   Reply With Quote
Old 01-04-2009, 03:52 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Remove the tiles it isn't that difficult. You can find a lot of reasons not to remove the tiles and one good reason to remove the tiles. The one good reason is so that your new floor installation will be successful.
Old 01-04-2009, 04:03 PM   #3
ok so the answer to my question is???? no
And how do I remove the tiles so "easy"
Old 01-04-2009, 04:10 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
A hammer and a chisel will remove the tiles.
An air powered floor chisel will remove the tiles.
An electric chipping hammer will remove the tiles.
An electric floor scraper will remove the tiles.
Old 01-04-2009, 08:37 PM   #5
onlinehandyman
Rewards Points: 125
Normally you can install the laminate over tile, but unfortunately not in this situation - you will need a hammer or a chisel or whatever works. We used to use a tool used for roofing that looked like an ice chopper to scrap the tiles up from the side.
Last edited by AtlanticWBConst.; 01-06-2009 at 05:18 AM. Reason: SITE RULES VIOLATION: Link Removed from Signature Line
onlinehandyman is offline   Reply With Quote
Old 01-05-2009, 06:01 PM   #6
Still Learning
I'm not sure if I follow this correctly, but I'm thinking you want to add a subfloor so it comes up to the height of the tile then install a floating floor over that? It's been done, but if you use plywood for the carpeted area, once the floating floor is installed it may become noticeable in sound under foot.
In other words, some may notice it while others will not. If that's important to you I would install some concrete backer board for a corresponding sound effect.
As far as tile removal. I've never considered it being easy! Some thoughts...
http://www.hardwoodinstaller.com/har...emove-tile.htm
HardwoodGuy is offline   Reply With Quote
Old 01-05-2009, 06:10 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There is no feasible way to install cement board over concrete.
Old 01-05-2009, 06:29 PM   #8
Still Learning
Really? Why not? Can't the backerboard be attached with tapcons?
Old 01-05-2009, 08:58 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The backerboard needs to be set in thinset. Tapcons could be used but what about the spoils that erupt from the hole when drilling through everything? Where are those spoils going to go especially with wet thinset down there to collect it. This will result in an eruption of the board. If two boards are necessary then you have double trouble. Cement board is irregular enough on its own without drawing it into wet thinset with Tapcons that are erupting spoils and forcing the boards upward at each fastener location. The surface could end up as smooth as a golf ball. This entire theory has been bandied around Internet forums for ten years now and the conclusion is installing cement boards to concrete is a losing proposition.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Old Tiles Removed - Now What?!?! Pineapple Flooring 5 10-14-2008 12:02 AM
calking backer board to tub glassman General DIY Discussions 13 06-19-2008 08:41 PM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 05:28 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 07:43 PM
