Float Cement Around Floor Drain - Flooring - DIY Chatroom Home Improvement Forum
Old 09-13-2010, 06:25 PM   #1
float cement around floor drain
Any tips on floating the cement in this image?
I'll be mixing quikrete plus some portland.
When should I saw down the floor drain pipe?
Do I need to be concerned about floating the cement up to the existing floor crack? It doesn't have to be perfectly level.
Thanks,
n2learning is offline   Reply With Quote
Old 09-13-2010, 08:14 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Have no idea what the heck you are doing!
Why is the floor drain fixture two feet in the air? Assuming that's what that is.
What is the overall plan?
Try again.
XXX
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 07:08 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
