Flexitech Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 04:46 PM   #1
me1
Thumbs down
flexitech flooring
DO NOT buy flexitech flooring it is garbage. Leaves impressions almost anything you set on it. Why would anyone want flooring that leaves impressions so easily?
me1 is offline   Reply With Quote
Old 09-20-2010, 05:00 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
Yes You can leave impressions in Flexitec. But you can leave impressions in any resilient floor with heavy appliances and furniture. Most people don't move their kitchens appliances, hutches Etc, around enough for it to matter.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 09-20-2010, 05:32 PM   #3
Support furniture with wide-bearing non-staining floor protectors. Ideally, protectors should be at least one inch in diameter, made of non-pigmented hard plastic and should rest flat on the floor. Use of non-staining felt protectors is also acceptable.
Did salepeople tell you this? Did you do this? This came right from some installation guidelines for flexitech flooring. Resilient flooring will make impressions
JCW355 is offline   Reply With Quote
Laminate flooring - several questions matt_ Flooring 10 03-23-2011 06:37 PM
Strange engineered wood flooring install in Philippines (pics) Flt_Simulation Flooring 7 10-05-2009 09:00 AM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
