Flexible Filler For 150 Year Old Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 01:12 PM   #1
Flexible filler for 150 year old hardwood floor
Hi,
I'm looking to refinish my plank floor which is original to the house. The gaps between the planks range between 3/8" and 1/8" and are 1 1/2" deep (room is 13'x15'). The previous owner refinished the floor using a standard wood filler; however, the planks shift as you walk on them and the floor gets pretty cold in winter so the filler has cracked and buckled. I'm hoping to find a flexible filler that I can buy in large amounts to fill the deep gaps across the entire floor.
Any suggestions would be appreciated.
Mel A is offline   Reply With Quote
Old 02-28-2013, 03:03 PM   #2
Rewards Points: 3,630
Originally Posted by Mel A View Post
Hi,
I don't think i would try and fill a 3/8" crack with any filler,unless you glue a piece of wood in first and have it at least an 1/8"below the surface.
I have no idea if the stuff in the link i'll add works,you'll have to decide that.
http://www.restor-it.com/what-is-the...-wood-fillers/
Canarywood1 is online now   Reply With Quote
Old 03-01-2013, 11:55 AM   #3
Thanks! I guess filling the gaps with thin pieces of wood and then filling it with epoxy filler might be best. Much appreciated.
Can I open the window at night if have solid hardwood floor installed qhwang Flooring 6 06-30-2010 09:36 AM
Carpet on hardwood floor, threshold hoozgrunt Flooring 1 07-15-2009 09:53 AM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 12:11 PM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
Clear Hardwood Floor Finish With Buildup CuCullin Flooring 3 11-18-2007 02:26 PM
