Old 11-19-2006, 03:04 PM   #1
Flagstone Patio
I want to cover an outside area with flgstone to make a barbeque/patio area. Part of this area is currently concrete slab and part is gravel. How can I acomplish this transition?
cpbraun is offline   Reply With Quote
Old 11-19-2006, 08:03 PM   #2
Tileguy
Bud Cline's Avatar
Flagstone Patio
.........and you don't want to add any more concrete I'll bet! Huh?
Old 11-21-2006, 02:17 PM   #3
Flagstone Patio
R&D Tile is offline   Reply With Quote
Old 11-21-2006, 03:42 PM   #4
Flagstone Patio
If all you want to do is transition from concrete to flag stone, I would dig out all the gravel, remove some dirt, put the gravel back and compact it like you would normally do for a flagstone installation. Compact it until your elevation+brick height= concrete level and you should be good to go.
billinak is offline   Reply With Quote
Old 11-21-2006, 04:43 PM   #5
Flagstone Patio
Sounds to me that he wants to place stone over the slab and the area where the gravel is, in that case, a concrete base is needed, unless you want all these stones moving around.
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
Small Patio Leenders Landscaping & Lawn Care 4 06-23-2006 02:30 PM
