-   -   Fixing squeaky/loud subflooring during carpet installation (http://www.diychatroom.com/f5/fixing-squeaky-loud-subflooring-during-carpet-installation-143242/)
thunderbry 05-09-2012 02:35 PM
I am getting new carpet put in on my 2nd and 3rd floors, and I want to fix some of my subflooring that squeaks and "moans" and makes other annoying noises.
I am a new home owner and have never made any fixes to subflooring so I don't know what to do.
My initial idea was to screw down areas that make noises once the carpet is pulled up by the carpet installers. I have read around and determined I should use 1.5" deck screws, #8.
Do any of the experts on this forum have any advice? Will those screws work? Do I need to pre-drill the holes through the subflooring into the joists? Or do I just screw the screws in without a predrilled hole?
Do I just screw in about an inch or so from the loose nails along the line of the joist? (I am assuming that the problem here is loose floorboards. Most of the sounds are not squeaking but "moaning" and "thumping" which sounds like the nails have become loose over time. The house is about 17 years old).
Thanks for the help.
oh'mike 05-09-2012 07:05 PM
Your plan sounds fine---Even the gold colored screws (never black drywall screws) work fine.
1 5/8" would be a better choice---
joecaption 05-09-2012 07:24 PM
What's there for a subfloor now. We need thickness, how many layers, and material it's made of.
gregzoll 05-09-2012 07:25 PM
To add, use the deck screws that have to use the square driver bit, not the ones that are phillips. They will not strip out if you have a problem driving them down. Place them next to where the existing nails are currently, and use bar soap such as Ivory bath soap on the threads, before driving, after you pre-drill through the sub, with a drill bit that is slightly smaller than the screws.
Just make sure that you use at least a six foot level to make sure that you are at least keeping the floor even across the area that you are securing. I would also do a 3 foot by 3 foot area, vs. just going along a straight path, so that you can use the least amount of screws to get rid of the squeaks.
thunderbry 05-10-2012 03:39 PM
Not sure exactly what my subflooring is, but I assume it is the standard 5/8 or 3/4" thick plywood.
If I go with the screws that need a square driver bit, can I use my standard drill with that square driver bit, or should I get a "screw gun" that I read about. Or should my standard drill work fine for this task?
I don't plan to do this in too many places, I only have a few spots that are really loud and need a fix.
Good idea about using a 6 foot level. Wouldn't want my floor to end up slanted. Wonder if I would notice anyway if it is slightly slanted. Probably not...
oh'mike 05-10-2012 03:58 PM
your standard drill will be fine---no need to buy a one use tool---
RhodesHardwood 05-10-2012 04:01 PM
Your plan will work out just fine. Just add the screws mentioned every 6 inches or so as needed.
