Old 11-22-2009, 05:10 PM   #1
Fixing low spot on subfloor
DYI gurus,
I am planning to install BR111 Triangulo 3/8" engineered hardwood using staple down installation. After I ripped up my carpet and the padding I noticed that the subfloor is now about 1" lower than the tile floor in the kitchen, dining and bathroom.
I plan on adding height by laying down 23/32" plywood using ring shank nails.
I noticed however, that there is a low spot located along a hallway where the lowest spot is about 3/4". The total length of the low spot is about 5" long slowly dipping to its lowest at 3/4" at around 2 1/2 feet.
How can I solve this problem? I don't think I can raise the current subfloor in that area because there is wall structure on both sides.
Thanks for any help on this.
JoseB is offline   Reply With Quote
Old 11-22-2009, 05:51 PM   #2
ArmchairDIY's Avatar
it may be possible to trowel on a floor leveler to bring the existing subfloor up to the proper level and then lay your new underlayment over top. It may take several applications depending on the product you use.
"It looked good on paper, but paper is funny that way"
Time to Get Up Out of Your Chair and Do it Yourself!
ArmchairDIY is offline   Reply With Quote
Old 11-22-2009, 06:00 PM   #3
Would there be an issue if I nail ring shank nails that I will use to attach the new plywood underlayment through the floor leveler compound into the existing plywood?
If I used a leveling compound, what would be the recommended way of attaching the new plywood underlayment onto the leveling compound?
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Removing subfloor nickdu Flooring 3 07-28-2009 09:34 AM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Subfloor with High Spot anthony9887 Flooring 1 08-12-2008 09:51 PM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
