Fix Stair Tread? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-08-2014, 08:56 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 782
Fix Stair Tread?
Know it's rare, but it happened. I made a slight mistake. Without going into details, I cut a couple stair treads short. Since u had NO spare wood I left it as is.
How would you fix this? I have some small pieces. I could cut off a small sliver and glue it in. My worst spot is about 1/8" in width. All the other (3) are less than a 1/6". Those I will just caulk.
The rest of the treads are perfect.
So....sliver of bamboo or just caulk it?
ddawg16 is online now   Reply With Quote
Old 08-08-2014, 11:19 PM   #2
Davejss's Avatar
Rewards Points: 740
Remove it and do it right.
Davejss is offline   Reply With Quote
Old 08-09-2014, 12:00 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 782
They are glued down. It would be major carnage to remove them. MAJOR.
Stair tread and riser assembly amakarevic Carpentry 14 06-30-2013 07:44 AM
Replacing oak stair tread bryanp22 Flooring 6 01-15-2013 09:17 PM
Question regarding gap between stair tread and skirt Awachter Carpentry 8 09-21-2012 10:06 AM
Exterior stair landing tread size min/max? jackwashere Building & Construction 17 01-06-2012 03:15 PM
Repairing Broken Stair Tread RonnyK Carpentry 1 05-17-2006 02:37 PM
