Fix Hack Job - Flooring - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 07:18 PM   #1
fix hack job
i just bought a fixer and someone laid in a bunch of flooring (plywood) but not all of it is completely flat. i assume i have to tear out the plywood but how do i get flat floors if joists or something else is not flat ?
moreover, is it normal to have imperfect sub floors and then they somehow become less of an issue by putting flooring over them?
bobmane is offline   Reply With Quote
Old 03-02-2013, 07:34 PM   #2
DIY staff
Rewards Points: 7,174
You need to figure out why they are not flat-----sometimes foundation settling is the issue---other times the floor joist are sagged-----some times there is an addition to the house and some miss matched heights are involved.
Rip out the bad work---post pictures of what you find and you will find many members here with good solutions----
Old 03-02-2013, 08:02 PM   #3
Pro
JetSwet's Avatar
Rewards Points: 502
????!!!???.....oh my goodness lol
JetSwet is offline   Reply With Quote
Old 03-02-2013, 08:07 PM   #4
DIY staff
That foreign spam sure is colorful----
JetSwet (03-02-2013)
Old 03-03-2013, 09:23 AM   #5
Rewards Points: 236
darn, i missed it...
anyway. i have seen plywood that is not the thickness that it is stamped.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
oh'mike (03-03-2013)
Old 03-03-2013, 10:53 AM   #6
Pro
JetSwet's Avatar
Rewards Points: 502
We need more info from the OP to help further.
Old 03-03-2013, 10:15 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
It's not supposed to be according to modern standards. Ply is 1/32" thinner than its stated thickness. Better trees now I guess.
Jaz
Old 03-03-2013, 10:22 PM   #8
Rewards Points: 236
Jaz
i bought many sheets, 12 maybe. one of them is thicker than the others. and is marked the same as the others. and came from the same pile. and its not the sub floor causing it.
Old 03-03-2013, 10:46 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 388
huh, sounds like a quality control problem. What type/grade was it? Sheathing of underlayment?
Jaz
Power strip hack salex Electrical 3 01-31-2012 06:10 AM
Hack tire pressure monitor on GM's Wildie Automotive Repairs 2 01-12-2011 10:12 PM
Hack ONSTAR Wildie Automotive Repairs 3 02-28-2010 02:23 PM
I used to think I was a hack Mr Chips Off Topic 3 08-16-2009 11:43 PM
Hack Plumber? ... Oops -NO a licensed plumber! coyotehills Plumbing 1 12-01-2007 11:22 AM
