Fix Cracked Grout - Flooring - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 07:52 AM   #1
Rewards Points: 93
Fix cracked grout
I've got a similar question to a thread below. I have a crack in some grout that I'd like to fix. Can I just find a match and repair? Or might I have some underlying problem that I need to fix first? Here's a shot of the crack as well as a cross section from my basement stairs. The part of the house with the tile is on a slab (tri level house) but I can't tell if there is underpayment between tile and slab. Could settling of the slab cause this?
Fix cracked grout-image-1979099354.jpg   Fix cracked grout-image-2907382467.jpg   Fix cracked grout-image-3045925751.jpg
scottyv81 is offline   Reply With Quote
Old 09-22-2012, 08:07 AM   #2
Rewards Points: 2,516
I bet if you stand on those tiles with the cracked grout and move your feet up and down, you will notice very slight movement of the tile. Underlying problem is bad foundation. Unless I am missing something in your photos, I do not see any underlayment board. Here was my install: been 18 months on a 450 sq ft install and not a crack anywhere. You can't see much of the subfloor in my photo. Also supporting the floor are 2 x 10 joists spaced 16" O.C.
hammerlane is offline   Reply With Quote
Old 09-22-2012, 08:26 AM   #3
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
If it's on a slab he doesn't need a cement board underlayement. I don't see any crack isolation membrane like Ditra either. It's just tile set right on the concrete. If there is any movement in the slab it transfers through to the time. Since it's cracking the joints and not the tile itself I'm apt to believe those tiles may not be firmly mortared into place. If they were solid, cracks in the slab would telegraph right through the tile, not the grout joint.
Darkling Designs
poppameth is offline   Reply With Quote
Cracked grout on shelf over sink - How to fix? Regrout? Caulk? thinksincode Plumbing 5 03-12-2012 08:09 AM
How to float grout to level cracked tile mosaic oggy bleacher Tiling, ceramics, marble 4 05-11-2011 07:24 PM
Grout lines in shower floor cracked and mortar is oozing out. megg Flooring 2 03-30-2010 06:35 AM
Cracked grout??? cm3putter Tiling, ceramics, marble 9 03-05-2010 07:49 PM
New shower, cracked grout Fleet_Foxes Tiling, ceramics, marble 10 02-18-2010 07:40 PM
