Fitting Solid Wood FLooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-14-2011, 05:05 AM   #1
What is the best way to fit a solid oak floor on concrete ?
albany is offline   Reply With Quote
Old 12-14-2011, 09:59 AM   #2
Rewards Points: 13,228
Not a good plan.
Engineered hardwood would be better. Go on the manufactuers web site you pick and look up the install instrutions.
It will end up being a floating floor with a vaper barrier under it.
Old 12-14-2011, 03:45 PM   #3
? is the wood itself solid glue down.tom wentzwood
wentzwood is offline   Reply With Quote
Old 12-14-2011, 03:50 PM   #4
It's glued at the T&G's not to the floor.
Just look up any brand of engineered flooring and look at the directions on how to install it.
Making some wood work using 2 1/4" hardwood flooring planks htabbas Carpentry 3 12-03-2011 09:30 AM
Putting wood flooring on steps timbo59 Flooring 4 11-18-2011 06:20 PM
Laminate wood flooring on slab newb questions shark974 Flooring 3 11-11-2011 06:57 AM
Electric Outlets under wood flooring jeh154 Electrical 3 08-09-2010 11:05 AM
Self levelling compund for wood flooring Mackenziewood Flooring 3 04-22-2010 05:22 PM
