#1 |
Fitting newer laminate floor boards to older obsolete ones...
So I've learned (the hard way) and haven't ever seen it mentioned on line, anywhere, (and I'm researching!!) that when you install a new laminate floor, buy TONS extra (not the "10% extra" you seen mentioned...)
because, in just a couple years, the tongue and groove style WILL CHANGE, and be NO LONGER CONPATABLE with any replacement boards you have to now buy... And that is my delema.. How do I replace new boards that "almost" fit together, with older (and not that old, 8 years...) boards? Water leaked and delmaninated 6 boards in the middle of a room, and need to be replaced. Cut them out, and then what? Help....! Sincerley, RicklesssssssssS in Oregon |
#2 | |
Fitting newer laminate floor boards to older obsolete ones...Quote:
#3 |
NACE Coating Inspector
shave the tongue. splines. its only wood, its workable.
| Display Modes | |
| Ditra under Laminate Floor? | HECO | Flooring | 3 | 04-30-2012 09:00 AM |
| laminate moving in one direction | nlmedic | Flooring | 2 | 03-01-2011 08:38 PM |
| Counter top plastic laminate | Gerry Kiernan | Interior Decorating | 4 | 10-13-2008 11:44 AM |
| Laminate layout, underlay for concrete subfloor? | Jen25 | Flooring | 2 | 09-30-2008 01:04 AM |
| How to reuse a ABS fitting guide | n0c7 | Plumbing | 4 | 08-27-2008 06:30 PM |
