Old 10-03-2005, 02:48 PM   #1
First time tiler caution
Here’s a tip for the first time ceramic tiler. I learned this by sheer chance from a flooring guy at Home Depot. I laid ceramics in my kitchen on top of an additional 5/8” ply subfloor on top of the existing. I think most people know this already as an alternative to the wire and cement route which can be difficult for the beginner. By luck, the guy noticed that I had bought 12” x 12” tiles and ceramic tile adhesive to stick them down and this is where the tip came in. He explained to me that ceramic tile adhesive should never be used on tiles larger than 8” x 8” as it dries too quickly around the perimeter and eventually stops air from getting to the centre where the adhesive stays wet. He said that if the leg of a chair was on the middle of the tile and someone sat on it, it could crack the tile. The proper way of laying bigger tiles was to use a mortar mix instead of the adhesive. Made sense to me after he explained, maybe saved me a lot of heartache and a good beating from the wife. Just something that the first timer wouldn’t think of. It would be interesting to see if any of the flooring pros here agree.
'Andyman is offline   Reply With Quote
Old 10-03-2005, 06:09 PM   #2
rspainhower's Avatar
NEVER use the premixed(mastic) adhesives. Always use a thin-set made with portland cement that you mix with water, it will work for any size tile from mosaics to 24 x 24. Again, NEVER USE MASTIC/PREMIXED ADHESIVES.
rspainhower is offline   Reply With Quote
Old 10-03-2005, 08:11 PM   #3
Floorwizard's Avatar
well said
Floorwizard is offline   Reply With Quote
Old 10-03-2005, 11:14 PM   #4
renovations
The mastic, even when cured, is water soluble and turns into paste if/when it gets wet. It has no place anywhere that might ever get wet. (Like a kitchen or bathroom). Rich.
Bonus is offline   Reply With Quote
Old 10-03-2005, 11:25 PM   #5
Carpenter
DecksEtc's Avatar
What floor doesn't get wet?
Terry
DecksEtc is offline   Reply With Quote
Old 10-04-2005, 02:14 AM   #6
renovations
OK, OK Decks,I agree, it has no place anywhere! God knows it's awful stuff to use.
Help! A/C leaking big time IncHulk HVAC 5 03-29-2008 09:27 PM
Why is my a/c weak every time I turn it on for the season? yummy mummy HVAC 48 08-07-2007 11:15 PM
First Time Home Buyer in Need of roofing thoughts 1stTimer Roofing 1 06-22-2007 09:49 PM
Tiling over time Duppy Remodeling 2 04-07-2007 01:12 PM
first time using a texture gun samf Remodeling 9 12-14-2006 08:16 PM
