First Tile Job, What's The Best Place To Start? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-07-2010, 08:38 AM   #1
First tile job, what's the best place to start?
I'm going to tile my laundry room tonight, and it's the first time I've ever laid tile. It's only 66 square feet. I've laid the chalk lines down the center (red lines in my drawing) and checked for square and done a rough lay of the tile. Where should I start? My plan was to start in the 1st quadrant and move in a clockwise position. What's the best way to move through the room and make sure everything stays square and even without trapping myself.
Thanks!
dwalls32 is offline   Reply With Quote
Old 05-07-2010, 06:12 PM   #2
firehawkmph's Avatar
Rewards Points: 1,922
DW,
Everything looks good. I would do like you are planning except leave the door quadrant for last so you can have a little more room to work. Take the door off to make it easier.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-07-2010, 06:19 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 422
Obviously you're installing ceramic tiles which you confirmed by worrying about being trapped. However, the way you marked the lines is not the way I'd do it. That is OK for vinyl, but not ceramic or stone tiles.
You should be starting off of the short wall on the right, opposite the door. The short north-south line should be about 2 tiles, (assuming the tiles are 12-14" or so), away from that way+-. The long line can be adjusted for best layout. You install the tiles going wall to wall, not in quadrants.
You didn't include measurements of the room nor tiles, so that's about as much as I can offer.
Jaz
Old 05-07-2010, 06:26 PM   #4
I would also figure out, on paper, where every single tile is going to land relative to the walls and door openings. You don't want to put down a tile that is 1" x 1".
Don't forget to allow for the grout thickness, and use spacers.
Old 05-07-2010, 06:37 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 422
Spacers..........? Spacers are for rookies! OH.....I forgot. OK then.
DW, I'm sure you're well into the project by now. How is it going?
Jaz
Old 05-07-2010, 06:50 PM   #6
Originally Posted by JazMan View Post
Spacers..........?
Gold Hat: "[Spacers]? We ain't got no [spacers]. We don't need no [spacers]! I don't have to show you any stinkin' [spacers]!"
Old 05-07-2010, 07:48 PM   #7
Thanks for the replies guys. I am well into it. Working in quad 1 and down and then towards the door. So far about 25% of the way through and no major incidents. I'm waiting for neighbors to call the cops about the tile saw
Old 05-07-2010, 07:59 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 422
Well, OK. Go to quad #2, then do # 3 & 4 at the same time.
Most cities have noise ordinances which takes effect at 9 pm. OH - OH.
Jaz
Old 05-21-2010, 08:02 PM   #9
Not the best photo, but here is the room with cabinets, flooring and baseboard installed. Thanks again for the help guys!
Old 05-22-2010, 10:25 AM   #10
DW,
Looks like everything turned out nice. I like all the storage. Tile looks nice and neat.
Mike Hawkins
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
Fitting a replacement floor tile applemac01 Tiling, ceramics, marble 7 03-04-2010 07:44 AM
foundation crack -- uncovering footing AFTER interior drain tile put in? downers Building & Construction 6 05-18-2009 12:07 PM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
