Fireplace Trim Options - Hardwood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-14-2010, 02:37 PM   #1
Rewards Points: 150
Fireplace trim options - hardwood floor
I am going to install my first hardwood floor in a small room. From what I have read, it seems like a have three options for the trim around my granite fireplace slab:
1. Cutting slab and lay floor underneath (don't want to attempt cutting granite)
2. Picture frame
3. Using threshold/endcap trim
I have seen pictures for #1 and #2. I'm not sure if I want to attempt cutting grooves with a router for the picture frame technique. Does anyone have any pictures of #3, it seems the easiest of three possibilities...does it look cheap? The picture framing looks awesome, just not sure about trying it. Thanks from a newbie.
joemontana16 is offline   Reply With Quote
Old 01-14-2010, 10:38 PM   #2
msv
Hardwood pro
msv's Avatar
go for picture frame with the corners joined in a 45 deg. angle...what type of wood are you installing? what method?
Fireplace trim options - hardwood floor-dscf3164.jpg   Fireplace trim options - hardwood floor-dscf3168.jpg
50% down, 50% after all your complaints....
Hardwood Floor Refinishing Roswell
msv is offline   Reply With Quote
Old 01-15-2010, 04:28 PM   #3
Rewards Points: 150
Bruce oak 2.25 Picture frame method looks awesome...I'll have to practice using the spline.
Strange Colors in Old Hardwood Floor LeanneP Flooring 7 06-04-2009 10:06 PM
hardwood floor transition from old to new cooter Flooring 4 05-25-2009 11:20 AM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 10:52 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
