Finishing Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-02-2011, 01:11 AM   #1
Rewards Points: 119
Finishing wood floor
Going to be sanding and refinishing our oak hard wood floor. What's the best kind of a sander that I should get for doing in and around small areas (like corners, along walls, the closets)- orbital, belt, palm?
debd is offline   Reply With Quote
Old 04-02-2011, 06:22 AM   #2
woodman58's Avatar
Fein sander would be tool of choice. But Here Harbor Freight has a knock off that would work well and is easy use to what you need.
http://www.harborfreight.com/variabl...ool-67537.html
woodman58 is offline   Reply With Quote
Old 04-02-2011, 07:59 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Carbide-tipped paint scrapers work fast and smooth.
Ask anyone who refinishes floors and wood stairs.
I use these from Sandvik. The blades are reversible and replaceable.
They get right into the corners and many times don't require any further sanding.
tcleve4911 is offline   Reply With Quote
Old 04-02-2011, 03:05 PM   #4
Rewards Points: 119
Thanks, very helpful!
Old 05-01-2011, 06:28 AM   #5
the machine doesnt matter really, it's the knowledge behind it, if you dont know exactly what your doing your gonna make a big mess... no offence
For small areas you would have to use and edging sander, they are basically like chain saws, if you don't know how to run one you will definatley tear chunks of wood into your floor.... but if the floor is really beat up already and you dont mind taking the chance.. youtube a few videos and give it a go.
Best choice, call in a pro, they;re expensive but for a reason, they;ll make your floor look like it's practically new.
your choice
Hoquester is offline   Reply With Quote
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Old wood flooring - leaks from second floor p<0.05 Flooring 7 05-20-2009 04:41 AM
Wood Floor Spacing Dilema rocketdoctor Flooring 2 05-15-2009 11:46 PM
Wood floor help/suggestions bigboyjoel Flooring 18 12-31-2008 12:02 PM
Best subfloor and material thickness nugentcn Flooring 7 09-07-2008 12:48 PM
