Finishing Up A Refinished Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-07-2009, 09:43 PM   #1
Finishing up a refinished floor
I am about to apply my 3rd coat of poly to my floor, it is not shiny. Is there something i can do once it is finished like buffing it.
onenonlydano is offline   Reply With Quote
Old 04-08-2009, 06:41 AM   #2
Remodeling Contractor
What gloss are you using? You could increase the gloss level for the top coat. You could wax and buff the final coat, but then you need to maintain this. Not a good way to go.
Old 04-09-2009, 05:52 AM   #3
Rewards Points: 264
The Poly your using will determine the sheen or gloss of the floor. Most come in satin, semi-gloss or gloss. I like to do my 1st to coats using a High GLOSS finish then top coat with Satin or semi-Gloss. I was told a while ago that the gloss Poly has more Polymers therefore it fills grain better. I just think it gives the floors a deeper look thats why I do it that way. Here's a pic of my current project. It only has the 1 coat of Poly-urethene on it so far.
other pics can be seen at new wood flooring
Good luck with your Floor. They can be a lot of work
Jim
What have I done is offline   Reply With Quote
Old 04-09-2009, 06:35 AM   #4
Increasing a gloss is done by polishing with increasing grit compounds. Use this for furniture, but it would seem to be not practical for flooring.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 02:37 PM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 11:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
