Finish Piece In Front Of Brick Fireplace? - Flooring - DIY Chatroom Home Improvement Forum
Old 05-11-2010, 04:25 PM   #1
Rewards Points: 264
Finish piece in front of brick fireplace?
Hi all,
Installing a new Pergo (floating) floor and don't know how to "finish" the floor around the fireplace in the middle of a wall. Normally just 1/4 round over the top along the edges but the fireplace has a 9' wide face of brick, and the grout lines of the brick are very deep. Glue the 1/4 round to the brick? Skip the 1/4 round? Thanks for your help!
moneymgmt is offline   Reply With Quote
Old 05-11-2010, 08:10 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 422
Get a threshold
Hey neighbor,
No 1/4 round. You're supposed to use what they call a "threshold" there. Looks like this:http://common1.csnimages.com/lf/1/ha...ue+Natural.jpg
The vertical part against the brick, be sure to leave about 1/2" space as shown.
Jaz
Old 05-11-2010, 08:16 PM   #3
Rewards Points: 264
Well that makes a lot of sense, thanks! Next question.... the thresholds I've used sit generally in a plastic U channel that is fixed to the floor, but this is going over concrete so how should I secure it to the floor? And is there even a U channel under the piece in your pic?
Old 05-11-2010, 08:27 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 422
Yea, the moldings for laminates are a little different. You can still use the one I suggested in a color that comes close to your laminate. Glue the bottom to the slab & the back to the brick. Make sure the Pergo is free to move cuz it's gona do alot of that.
Jaz
brick wall on front of house is leaning Brendawyatt Concrete, Stone & Masonry 6 12-03-2012 07:38 AM
Brick Fireplace Paint ... g8master Building & Construction 3 12-20-2009 12:31 PM
Mounting TV Bracket on Brick Fireplace tanner21 Home Theater 5 05-13-2009 10:59 AM
Slurry finish over brick stonesmith Building & Construction 1 08-12-2008 09:11 PM
Stucco Finish Type Paint Over Brick water_cutter101 General DIY Discussions 8 06-17-2008 09:40 PM
