Finding Matching Carpet - Flooring - DIY Chatroom Home Improvement Forum
Old 12-22-2013, 12:15 PM   #1
finding matching carpet
Hi,
We will be putting our house on the market in the next month so and currently making improvements. We have berber carpet in the master bathroom and stairs and two bedroom second floor. The carpet in the stairs and bedroom on the second floor is in fairly good condition because it has not been used much. We need to replace the carpet in the master bedroom - the problem is that I can't find the same carpet anywhere (well, so far I have looked at HomeDepot and Lowes - in store). This is the original carpet in the house - the house was built in 2001. How should I go about finding the same (or very similar) carpet to replace only in the mastered?
Thanks,
M
mikeinMemphis is offline   Reply With Quote
Old 12-22-2013, 12:26 PM   #2
Rewards Points: 153
Go to a carpet specialist. They can find the best available match - it will probably be special order.
eandjsdad is offline   Reply With Quote
Old 12-22-2013, 03:52 PM   #3
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Very little chance that you will find the same. Carpet styles and colors change constantly. Any chance you would have the bill from installation? It might give you the manufacturer. Other than that, I would take a piece of it around to some independent stores and see if they can come close.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 12-22-2013, 04:55 PM   #4
K&B Designer
Live_Oak's Avatar
Go see MaryMargaret at ProSource. 901-388-8848. She knows carpet very well. Bring a sample with you. The same carpet most likely isn't being made, but she can probably find you something similar.
Do it right from the beginning if you only want to do the job once. It'll be cheaper in the long term.
Live_Oak is offline   Reply With Quote
The Following User Says Thank You to Live_Oak For This Useful Post:
mikeinMemphis (12-23-2013)
Old 12-22-2013, 08:36 PM   #5
Rewards Points: 220
imo. just get something that looks ok alongside what you already have. doesn't have to match.
Fix'n it is offline   Reply With Quote
Old 12-23-2013, 11:40 AM   #6
This is going to be a stupid question - I don't have a sample of the carpet, so shall I just cut from a corner to bring to ProSource? Photos from my iPhone won't work?
Old 12-23-2013, 12:13 PM   #7
bbo
the sample will also show them the pile and backing, among other things.
another thing to consider is putting some type of laminate or hardwood or something in the MBR. in our other BDR we have carpeting, but our MBR has hard flooring. we use a rug to bring warmth into the room.
bbo is offline   Reply With Quote
Old 12-23-2013, 01:04 PM   #8
K&B Designer
Live_Oak's Avatar
Pictures are never enough if you want a good match. You also need to figure out which fiber is being used, it's weight, and a whole lot of other things that don't show up except in person. Sometimes there will be a mill mark on the back of carpet, and that can help a lot. Also, you want to be able to assess the condition of the padding under the carpet, especially if there have been pet accidents or other types of spills. That usually means it's mandatory to replace the padding as well, even if you're moving and don't really care about carpet longevity.
Grinding concrete to remove carpet glue, and matching height of existing laminate... dmh0284 Flooring 12 04-22-2015 05:51 PM
Mixing and matching carpet brookbend1 Interior Decorating 3 09-23-2013 04:20 PM
Carpet Flooding and Replacement airjay81 Flooring 1 05-08-2012 01:00 PM
Finding Joists Under Carpet Question dajonx Flooring 11 02-01-2012 01:23 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
