Finding Joists Under Carpet Question - Flooring - DIY Chatroom Home Improvement Forum
Old 01-30-2012, 08:58 AM   #1
Rewards Points: 27
Hi,
I was wondering if anyone has a good way to find joists under the carpet. I purchased the "Squeak No More" and I was using the joist finder bit in numerous spots in the upstairs bedroom. Their instructions were that if you reverse the bit, it should bring the drill back up automatically if you were on a joist. However, it seemed like it was happening every spot I was testing (within 16" of each test spot).
Does anyone have any suggestions in finding the joists under carpet easily?
Thank you!
dajonx is offline   Reply With Quote
Old 01-30-2012, 09:06 AM   #2
A Little Of Everything
Rewards Points: 1,356
All I've ever used is a hammer, and tapped repeatedly. The less "hollow" the sound, the closer you are to the joist.
DrHicks is offline   Reply With Quote
Old 01-30-2012, 10:35 AM   #3
Rewards Points: 27
Hahaha! It's as simple as that? I'll definitely have to give that a try. Thank you!
If there is a squeak in between joists, how should I fix that? (Please keep in mind that all this is new to me)
Old 01-30-2012, 04:29 PM   #4
If you are driving that joist-finding bit to the recommended depth and are not finding voids between joists, the real problem is most likely that there are multiple courses of flooring underneath the finished surface. This is common in remodeled or flipped homes where the remodeler didn't first remove the old flooring before installing new. Meaning:
___________________
Carpet
___________________
Underlayment (possibly X2)
___________________
Old/Original flooring
___________________
Original subfloor
___________________
Joist
___________________
Try running the screws just wherever the squeaks are. You won't hurt anything by doing this. Your goal is to suck all those layers together. Drive some where the joists are likely to be per Dr. Hick's suggestion, but centering over the squeaks, in your specific situation, will give you the most return.
Good luck!
RenoStruct is offline   Reply With Quote
Old 01-30-2012, 04:56 PM   #5
Rewards Points: 1,520
Usually floor joists run the same direction on all floors; look in basement or attic for direction (usually run the narrow length of a home).
Start at one wall and measure 16" increments til you get to your squeeky area; joist should be somewhere near where you measured for a start (if the prior methods don't work).
I've used the system and it really does work well for squeeks (although one squeek migrated about 10' from where I stopped it after about 2 weeks; but I don't walk too much where it is now so I'm letting semi-sleeping dog lie).
bob22 is offline   Reply With Quote
Old 01-30-2012, 05:02 PM   #6
DIY staff
Rewards Points: 7,174
Find a floor heating register (if you have forced air heat) and lift off the cover--you should be able to locate the framing from there---16" centers id most common
Old 01-30-2012, 07:50 PM   #7
I took a larger gauge finish nail and started pounding until I found one...I had an idea where to start and I was close. Once I found one I was able to measure off that joist
My humble Man Blog
jasonreck71 is offline   Reply With Quote
Old 01-30-2012, 08:06 PM   #8
Rewards Points: 12,802
Pull the carpet back with a pair of plyers, see the nails or screws? That's where the joist are.
Old 01-30-2012, 09:34 PM   #9
Tileguy
JazMan's Avatar
Rewards Points: 216
Jason,
Your method with the long finish nail is how I would do it to locate the joists. All those ideas are good and you need to use several at the same time.
Jaz
JazMan is online now   Reply With Quote
Old 01-31-2012, 10:13 AM   #10
Rewards Points: 27
Thank you very much for all of your suggestions!
I will definitely try the hammer tapping method, measuring out 16" from the wall, and continue to use the joist finding bit that came with the product.
I thought about pulling a section of carpet, but I'm hesitant because I'm unsure on how to put it back in. I'm also a bit hesitant in hammering in nails, but I guess it's the same as using that bit and drilling it in so maybe I'll give that a try as well.
So just to be absolutely clear in fixing floor squeaks, I should just screw in the subfloor to the joist only in the area where the squeaks are. If the floor squeaks still persist, there's nothing I can do?
Old 01-31-2012, 06:46 PM   #11
I will be using the squeek no more tool and screws this weekend. I am planning on doing a blog post on it if you are interested. I will take pictures
My humble Man Blog
Old 02-01-2012, 01:23 AM   #12
Too Short? Cut it Again!
They make a joist finding drill bit for carpet situations it is a long smooth shaft with but a few threads on the very tip. Mine came with this kit. This system works great and was featured awhile back on Ask This Old House.
The Following User Says Thank You to user1007 For This Useful Post:
DrHicks (02-01-2012)
The age-old question: cats and carpet sbattisti Flooring 7 03-19-2011 02:39 PM
Straps for securing gas line to joists - question. DangerMouse HVAC 4 07-05-2010 09:20 PM
Floor Joists of different sizes HooKooDooKu Drywall & Plaster 7 02-04-2010 06:43 PM
Question regarding removing ceiling joists... tonfan Building & Construction 9 11-19-2007 12:56 AM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 09:26 PM
