Filthy Stone Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 05-10-2013, 10:39 PM   #1
Filthy Stone Floor
I recently purchased a home that has a room with rough cut, porous stone and this floor is absolutely FILTHY! The previous owners apparently never cleaned it. My question is how do I clean this floor? Mopping doesn't seem to help since the filth has completely worked its way into the floor. My question is how in the heck do I clean this or am I stuck with this nasty floor forever? Someone suggested cleaning it with muriatic acid (yikes!) but is there a less caustic method to clean it?
gocubs_84 is offline   Reply With Quote
Old 05-10-2013, 11:50 PM   #2
Dave Sal's Avatar
Rewards Points: 666
You might want to try some 409 Natural Stone Cleaner. I bought a spray bottle of the stuff to use to clean up the fireplace hearth, which looked a bit dirty after years of use. The stuff worked pretty good too. I sprayed it on and used a scrub brush to work it in, and then rinsed with water and dried it. In your case you might want to rent a floor buffer with a scrubbing pad. I only did a small area so I didn't have to worry about breathing the fumes, and I honestly don't remember whether there were any, but if I were doing a floor I'd probably wear a respirator just to be on the safe side.
Dave Sal is offline   Reply With Quote
Old 05-11-2013, 01:10 PM   #3
Oso954's Avatar
Rewards Points: 1,114
Before hitting it with chemicals, I try a steam cleaner or steam mop on it.
Oso954 is online now   Reply With Quote
Floor joist replacement and reconfiguration WillK Carpentry 2 09-01-2011 08:01 AM
Subfloor and underlayments for stone floor LHO Flooring 6 07-31-2011 11:03 PM
Pet Sanctuary Needs Urine-proof, affordable floor which is not too hard. Pet Sanctuary Flooring 1 05-31-2011 04:53 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
