Old 09-06-2010, 06:06 PM   #1
Quick learner
Filling trenches in concrete basement floor
My friend just had some plumbing done in her new home. She had some drains for a bath and a sink placed in the floor connecting them into the main drain.
The contractor left wide trenches (1 foot wide) where he dug up the concrete and laid down the drain pipe. He put the pipes in a bed of sand, then put sheets of plastic over the whole thing. Now I have several feet of these trenches.
How do I fill and repair the trenches? Just mix up some concrete and put 'er down, or what?
chinaclipper is offline   Reply With Quote
Old 09-06-2010, 06:38 PM   #2
Civil Engineer
Option 1, call the contractor back to fill the trenches.
Option 2, you play contractor for the day, and fill the trenches with bag mix concrete (sakrete).
Option 3, the owner plays contractor for the day and fills the trenches with Sakrete.
Option 4, you leave the trenches, they are not likely to get any deeper on their own.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
chinaclipper (09-08-2010)
Old 09-06-2010, 08:08 PM   #3
Tileguy
Bud Cline's Avatar
Closing the ditches should have been discussed with the plumber before any work was done. Is there a written estimate? What does it include?
Your friend could close the trenches with concrete mix but that can be a heck of a lot of work if you don't know what you are getting into.
The Following User Says Thank You to Bud Cline For This Useful Post:
Old 09-06-2010, 09:31 PM   #4
Quick learner
OK I can do the work. No problem.
Mix and fill, right? Is it that easy?
Old 09-06-2010, 09:33 PM   #5
You take the fill and put it back in then fill the trench with about 4’’ of concrete and float it flush that’s about it...
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
Old 09-07-2010, 10:33 PM   #6
Tileguy
Bud Cline's Avatar
Not clear on what the plumber left you with. You don't want to surround any piping or fixtures with any concrete. The piping needs to be buried in sand up to its previous level below the existing floor. Then fill the rest with mixed concrete and smooth it off even with the existing surface.
Old 09-08-2010, 12:37 AM   #7
Quick learner
Good to know.
I will make sure the pipes are buried in sand, then fill and level the trenches with concrete mix.
Bob's yer uncle!
Thanks everyone!
Old 09-08-2010, 09:27 AM   #8
Super Moderator
Foam collars are available to keep the shower and toilet pipes free from the concrete--
A very good idea---
If the floor is to be tiled---do not over fill the trench--you can fill a low spot as you tile--
--but a hump---you don't want that headache.--Mike---
oh'mike is online now   Reply With Quote
chinaclipper (09-16-2010)
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
Repairs for concrete basement floor GoRaiders Building & Construction 1 05-23-2010 11:52 AM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
Join Wood Cyc Ramp to Concrete Floor Bigboots Building & Construction 3 11-27-2007 10:52 PM
basement bathroom (concrete floor drain plumbing) amakarevic Plumbing 4 11-27-2007 06:37 AM
