Filling Screw Holes - Flooring - DIY Chatroom Home Improvement Forum
Old 11-18-2011, 05:51 PM   #1
Filling screw holes
Redoing our bathroom. I screwed the subfloor down to the joists, because the floor was squeeking. That solved the squeeking. BUT, some of the screws sank into the subfloor a fair ways, more than just the float will deal with. I have Roberts, 8000 embossed floor filler. Do I just fill the screw holes with that and float the rest of the floor or do I use something else to fill the screw holes? What would I use if that won't work.
Thanks in advance for your response guys.
Smudgeboss is offline   Reply With Quote
Old 11-21-2011, 02:50 PM   #2
can't believe no one knows the answer to this
Old 11-21-2011, 03:20 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Nobody knows what the hell you are talking about, and why would you be concerned about sunken screw-heads in a subfloor. What am I missing?
Old 11-21-2011, 03:38 PM   #4
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 92
What will be the final floor?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-21-2011, 04:24 PM   #5
the subfloor was floated for the lino that was on before. I am putting starloc aspen slate floating floor on top. I would assume that eventually the flooring would dent down into the screw holes if they were not filled. am I right? what am I missing?
this should, I think and hope answer both the above questions.
Old 11-21-2011, 04:26 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So...That's a vinyl flooring product?
Old 11-21-2011, 04:36 PM   #7
yeah Bud it is. overlapping edges that glue to each other, and you don't glue it to the subfloor.
Old 11-21-2011, 04:38 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Never heard of it but yes, fill the holes and seams. I think a Portland cement filler product would be in order.
The Following User Says Thank You to Bud Cline For This Useful Post:
Smudgeboss (11-21-2011)
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 01:54 AM
wood dowels good for repair bad screw holes? darsunt Carpentry 10 08-12-2011 06:42 AM
filling screw holes lilmiss Remodeling 8 07-27-2011 02:29 PM
Robertson tip stuck in screw djgrant General DIY Discussions 4 07-05-2011 04:18 PM
Swapping old 3ways with new (different screw color configuration on new switch) Michblaze02 Electrical 10 11-08-2009 02:17 PM
