Filling The Inside Corners Of My Tile Shower - Flooring - DIY Chatroom Home Improvement Forum
Old 07-24-2010, 05:14 AM   #1
Rewards Points: 156
Filling the inside corners of my tile shower
Hey everyone and (oh'mike the only one that ever responds) I have a question. Where the tiled walls meet in the inside corners of my shower walls do I grout the seem or just use the matching colored caulk on these corners. I would only assume the caulk with no grout but again I am not totally sure and also what are some tips on getting the caulk to look really nice on the bottom edge of the tile on the base of the tub and also the corners. Thanks
ryan5068 is offline   Reply With Quote
Old 07-24-2010, 10:04 AM   #2
DIY staff
Rewards Points: 7,174
You will want to caulk all corners---different surfaces move at different rates-grout will crack in the corners and around the joints of the shower pan.
Silicone caulk or a highly flexible color match caulk are needed there.
Here is a technique taught to me many years ago.
You need ; a scrub pad for cleaning away any dust or crud. A spray bottle of 'Greased Lightning' or '409' and a roll of paper towels.
The first thing to know is that Silicone will stick to any dry surface---will not stick to a wet soapy surface.
1.Go over the corners with the dry scrub pad---removing any grout stuck to the face of the tile.
Using compressed air or an old paint brush clean away any dust.
2. Start applying a fine bead of caulk--start at the bottom and work your way to the top.
do the floor or curb joint first --pan to walls next --then wall joints.
3. After the section of caulk is applied--quickly spray it down with the soapy spray,slick up you finger-
and use that finger to shape the caulk,removing any excess to the paper towels.
As long as you didn't leave any gaps under the caulk--you will have a perfect silicone caulk bead.
Do one or two sections at a time--you need to be quick enough that the silicon does not 'skin' over before you spray it.
Please do a test of this on something before you try it on your finish work.
This technique is used by most Granite installers to get that perfect bead. There is a small learning curve--you need to avoid getting the spray on a dry area that still needs caulk-do a test first.--Mike--
Old 07-24-2010, 12:56 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Wonder why that is?
XXX
Old 07-24-2010, 01:11 PM   #4
Electrician
Proby's Avatar
Hey Mike, you wanna take a trip out to NJ to do my tile work?
All I've ever seen is the tile setter send the kid in to shoot the caulk and wipe it with his finger. No cleaning, compressed air prep work, no soapy spray, just a finger and a rag to wipe it on.
When hiring a contractor, how can you tell whether it's going to be a typical in-and-out hack job or someone who cares about their work and doing it right?
Proby is offline   Reply With Quote
Old 07-24-2010, 01:37 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ask for, then personally verify several references. Look at the ones you can. Talk to local retailers the installer may have done work for and get their opinions of his past performances. Remember, no installer will refer you to any unsatisfied customers so get enough references to satisfy yourself his work is generally up to par.
XXX
Old 07-24-2010, 03:50 PM   #6
DIY staff
I like to give references to the jobs that I'm on or a job that hasn't even happened yet.
Picking a tradesman is tough,when I need someone to do work for me I ask other contractors for a referral---then I do some checking on their work. A tile store might offer a few suggestions,they see the good and the bad.
This trade takes a while to learn,I suggest that you look for someone who has been around for a while.
---Mike---
Old 07-25-2010, 02:30 AM   #7
Rewards Points: 156
Hey Mike thanks again for the great tips. Tonight the wife and I finished laying all the wall tile. We got all the bullnose done and now we are ready to grout tomorrow night. what technique would you recommend on the stone inlay for grouting. Would you suggest a grout bag or something like that or just put it on and get it off with the rubber paddle. Thanks
Old 07-25-2010, 06:41 AM   #8
DIY staff
Just use the float. Make sure you wring out your sponges well.
Old 07-25-2010, 06:44 AM   #9
Rewards Points: 156
Okay Mike will do. I am really excited to get the project finished. Tiling is alot of work in many different steps. What consistency should I make my grout. Thanks
Old 07-25-2010, 06:59 AM   #10
DIY staff
About as thick as yellow mustard.
Old 07-25-2010, 01:32 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Dijon or Pure Prepared?
XXX
Old 07-26-2010, 01:53 AM   #12
Rewards Points: 156
Ok thanks I will post photos when complete!
replacing my current prefab shower unit with tile...Can I use the existing pan and just tile above it? Austin Kitchen & Bath Remodeling 1 05-20-2010 11:02 PM
Shower tile adhesive issues imcanadianeh Remodeling 2 03-26-2010 07:45 AM
Tiling Shower: Decorative tile thicker than Wall tile digexpressions Remodeling 11 06-08-2008 06:49 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
tile shower help Atricaudatus Remodeling 13 04-01-2006 09:38 PM
