Filler Marks On Timber Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 06-17-2011, 01:44 PM   #1
Filler marks on timber floor
Hi all, need some help. I've just laid a new floor of old softwood boarding which had been previously painted. Stripped it and sanded it to get all paint marks off. Then filled old holes and splits with PVA mixed with sawdust . Put on first coat of Granglaze (oil based) and all the filler marks show through. Any suggestions on how to get a more even finish. I don.t mind staining the floor a darker colour. I,ve tried Danish oil and also wax polish on different parts of the floof but filler still shows through.
LEPPY is offline   Reply With Quote
Old 06-17-2011, 08:50 PM   #2
woodman58's Avatar
I don't beleive it is the final finish that is causing the filled area to show. The Polyvinyl acetate (White Glue, Carpenter's glue) will darken the saw dust. By darkening the wood with stain this should lessen the visibility of the filler. It will still show, but by adding moisture to sawdust it makes it darken and locks it in as it dries.
woodman58 is offline   Reply With Quote
Old 06-18-2011, 05:58 AM   #3
hi woodman58, thanks for that but the filled area is lighter than the sealed floorboards.I've prob used too much filler and this has spread round the holes. I,ve only done half the room so happy to sand it all again.Can you suggest a stain, would actually like it a bit darker cause it,s in a 250 yr old stone house and the finish at the moment looks a bit 70,s. I,ve used dark liberon wax polish before in a previous house and liked the finish but thought the granglaze would be more hard wearing and less maintenance.I want to get it right cause this is the main living room but I also have the whole upstairs to do as well. Thanks
Old 06-18-2011, 08:26 AM   #4
woodman58's Avatar
I assumed that the glue would darken the sawdust. Sorry! If you use Cyanoacrylate (super glue) it should darken the sawdust. Then add the stain of your choice. I don't have a preferance. I do like a gel stain for furniture but, it would be expensive for a floor. As for the final finish, I only use a poly for floors because of time restaints. I like a lacquer finish for furiture.
Filler between floor joists in old home TATTOO15 Flooring 0 04-15-2010 10:27 AM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 09:59 PM
Best nail hole wood filler for hard wood floor Radjack Flooring 4 04-16-2009 09:17 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
