Fill In A Hole In My Wood Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 10:07 AM   #1
Rewards Points: 150
Fill in a hole in my wood floor
Hello everyone,
Ill be changing my heating system, and will be removing my cast iron radiators. These radiators have a pipe that goes through my wood floor (see pic, towards bottom left, youll see 2 pipes that disappear into my floor) Upon removing the rad`s and pipes, Ill have a couple of holes in my wood floors. Whats the best way to fill them up? Cut out little cylinders of wood, and fit them/glue them in?
Any idea's?
sbmfj is offline   Reply With Quote
Old 03-16-2011, 10:11 AM   #2
Still Learning
Here in los angeles we can buy plastic caps to fill the hole. They look pretty clean. Check if your local hardware store carry's it
thehvacguy is offline   Reply With Quote
Old 03-16-2011, 10:18 AM   #3
Rewards Points: 150
I dunno about plastic. DO you have a pic? Or is it just some random plastic piece used to fill in the hole...?
Old 03-16-2011, 10:24 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I've done the hole plug thing before and it always looks like that....a hole plug.
I've also cut out the piece of flooring and replaced it. Much better final product, but much more work.
If you opt for the R&R, you can sometimes get a piece of the flooring from a closet or under the stove or refrig.
Just cut out what you need, and put back a chunk of wood to fill the gap.
tcleve4911 is offline   Reply With Quote
Old 03-16-2011, 08:01 PM   #5
woodman58's Avatar
I agree with 4911. Cut it out and use wood from a closet. If you have no idea how to do this, don't try it. Hire a professional. It is not an easy thing to do. You can end up damaging more boards than you care to.
woodman58 is offline   Reply With Quote
Old 03-16-2011, 08:46 PM   #6
Still Learning
Many ways to skin a cat. I like that idea better for exposed floor. Where i used the plastic cap you couldnt see it. There was a washer and dryer on top of it. I dont have a pic, but it worked.
Old 03-17-2011, 08:23 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Here's a nice DIY video showing the process
Old 03-17-2011, 04:27 PM   #8
I would fill the hole with a filler like newspaper and then use an epoxy wood filler. This can be stained to match the wood and then you can use color pencils to simulate the wood grain and put a sealer over it.
JohnRocks is offline   Reply With Quote
Old 03-17-2011, 04:37 PM   #9
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can stain epoxy ?
How's that work?
XXX
Old 03-17-2011, 04:59 PM   #10
Five Star User
I have used a stained epoxy and it worked very well.. Good idea JohnRocks
indymaker is offline   Reply With Quote
Old 03-17-2011, 06:47 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So do you buy it pre-colored or stain it after it is installed?
Never heard of it.
XXX
Old 03-17-2011, 09:06 PM   #12
Five Star User
You get it in a plain color and can add the coloring to it when it is a liquid or after it has hardened. It has a quick dry time so if you don't know what you are doing you would need to do it after. as it takes a bit of experience to do it in the liquid state. Make sure it is the type for simulating wood.. not expoy ahesive.
Old 03-17-2011, 10:14 PM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Does it have a name?
XXX
Old 03-17-2011, 10:36 PM   #14
Wood Worker
RiverOaks's Avatar
They call it epoxy wood filler, several companies make it. I have used it on some of my projects. When I have large holes in a project I do the same type of thing.
RiverOaks is offline   Reply With Quote
Old 03-18-2011, 12:50 PM   #15
Rewards Points: 150
thanks, found this on the web...
http://www.hammerzone.com/archives/d.../rot/epoxy.htm
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
snake speaker cable under wood floor? mikeasmel Electrical 11 02-15-2011 12:40 PM
Installing floating floor over squeaky wood floor- rip it up? (Q3) cee2ski Flooring 1 02-09-2009 06:23 AM
Fill hole in hard wood floor in discrete location? pcampbell Flooring 2 05-20-2008 08:23 AM
