Fill In An Area With Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 04:43 PM   #1
Solutions (handyman)
Rewards Points: 364
Fill in an area with laminate flooring
My Client has a mobile home which used to have a dividing wall between the living room and the kitchen. All floors were done in laminate. She removed the wall and, of course, found no laminate where the wall was. She thinks she wouls like a strip on laminate running at right angles (where the wall was) across the entire floor, to provide a visual seperation.To do this I would have to cut the existing laminate where the flooring used to meet the former wall, plus extend the cut out wall to wall. This means the former floor would not have the lip to receic=ve any additional boards and the new boards , .... the lip would have to be removed. I'm thinking this is possible but the new boards would (probably) have to be glue down to a solid sub-floor. Any advice or suggestions would be appreciated.
Mark Harvey is offline   Reply With Quote
Old 07-04-2012, 06:49 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
Post a pic if you can but laminate can not be glued to subfloor, if you don't have a male and female end it won't work that way.
JetSwet is offline   Reply With Quote
Old 07-04-2012, 07:07 PM   #3
Rewards Points: 14,294
Not going to happen for several reasons. Laminite has to float, put it againt a soild surface and it's going to buckle up. It would need a trasition strip to allow it to float which would look like poop.
Best idae is to reinstall the whole floor.
How are they going to deal with the ceiling and wall?
JetSwet (07-04-2012)
Old 07-04-2012, 07:35 PM   #4
Rewards Points: 364
All good points. I will suggest redoing the floor, this make the most sense to me. Other than that, I think any other quick fix will look like a quick fix. Even if I trim the edges, if I don't glue the new stuff down, it won't have anything to grab on to. It would "float" but without being attached to the old floor, it would probably buckle or lift. I thought of a transition piece or some trim but again, that would look like a quick fix. I appreciate ideas and comments.
Is it ok to carpet over laminate flooring? pekie Flooring 7 02-20-2010 01:20 PM
Laminate flooring to concrete abndaddy1994 Flooring 2 02-06-2010 08:26 PM
laminate v. hardwood flooring JDuc Flooring 11 01-13-2008 09:01 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 08:35 PM
