A Few Final Laminate Questions... - Flooring - DIY Chatroom Home Improvement Forum
Old 11-08-2007, 08:47 PM   #1
A few final laminate questions...
Ok, floor is just about done! It was easier than I thought. Just a few questions.
1) When sealing the floor around doors and other places where water might be an issue, do you apply the sealer on top of the vapor barrior to keep water from getting between the barrior and the floor? Or do you cut the barrior right where the floor stops and seal both the subfloor and the laminate? I have the vapor barrior running all the way to the edge of the walls so after the floor stops, there is the 1/4 inch of barrior protruding up to the wall. Hope that makes sense.
2) When using the 4 in 1 moudlings, do you recommend screwing, nailing or just glueing the plastic track to the subfloor? (I am working with slab).
Thank you for all the help so far!
CD08 is offline   Reply With Quote
Old 11-09-2007, 12:35 AM   #2
Tileguy
JazMan's Avatar
Rewards Points: 290
Sealing...sealing for what? You can't seal a laminate to be water tight. If you get too much water on the floor too many times, you're not gonna be happy.
You should follow the instructions all manufacturers put on their products. There are so many laminate these days.
Jaz
JazMan is online now   Reply With Quote
Old 11-09-2007, 07:29 AM   #3
Handyman
When sealing (I presume you mean sealing the 1/4" expansion joint around the perimeter of the room) it won't matter if you seal over the underlayment barrier or not. If your on slab and ran the barrier to the wall just seal over the underlayment. In regards to the molding just glue that down over slab (don't want to think about nailing or screwing that thing into slab) just use a liquid nail type glue and your good to go.
UKMatt is offline   Reply With Quote
Old 11-09-2007, 12:29 PM   #4
Correct, I was talking about the expansion gap. Good, I was hoping I could glue it...the directions say to screw it to the concrete and I was dreading that. Thanks!
Old 11-09-2007, 04:25 PM   #5
Floorwizard's Avatar
UKMatt hit the nail on the head.
good advice.
Floorwizard is offline   Reply With Quote
Old 11-11-2007, 02:38 PM   #6
Sorry, 1 more question... should I glue the track or ditch it and just glue the transition directly to the concrete?
Old 11-11-2007, 05:25 PM   #7
Handyman
Pitch the track, glue direct to concrete.
Old 11-12-2007, 01:04 PM   #8
Thanks!
a few laminate floor install questions mcvane Flooring 5 11-21-2014 02:34 PM
Help me Choose a Laminate Brand DYI_DD Flooring 21 11-15-2008 03:25 PM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
questions about buying laminate flooring darsunt Flooring 5 09-21-2007 09:47 AM
Laminate Flooring Questions... sootybuttercup Flooring 1 08-13-2006 09:35 PM
